Gkreidt
Everything posted by Gkreidt
  1. Guessing we were 7 miles west of Minnedosa
  2. sure did, went by the geographical center of North America marker and also went by the scientific center of North America near the town of Center ND not far from home.
  3. Well finally made it to Canada to get the tractor. Border crossing either way was no issue, just had to claim cash we had with us. Very happy with the condition of the old Titan. Brought it home yesterday 4-19-26. Still some snow around Minnedosa and Rapid City MB. Will be looking for an original water tank, so if anyone knows of where to find one would appreciate you letting me know.
  4. Will be going to a farm somewhere NW of Brandon MB. Just haven't been able to get together on it yet, the weather is either bad here or there or both. Owner has to come from Winnipeg. Planned on going Tuesday but sounds like a bit of snow at the farm again so wait for the weather to get better. whenever it happens and we make a deal I will post what we got and how the crossing went.
  5. Thanks for the replies. Called border crossing and talked to 2 different agents. Kinda got 2 different stories on what to expect. One agent I could tell would be very by the book. the other agent told me If he was at the border I would have no problem. Main thing is that the tractor was made in the US so their will be no duty or tariff, it is old and a collectible being sold by a private individual to another private individual for their own use. So hopefully It should not be a problem brining it back.
  6. Possibly making a deal on an old IH tractor in Canada. Plan on going to look at it, will take a trailer with so we can bring it home right away if we make a deal. Have passport but got to thinking if bringing a tractor back is going to be an issue at the border? has anyone on here had any recent experience with this? Plan on calling port of entry for information.
  7. Have been a subscriber since the start, think I have every issue
  8. Gkreidt
    $31500 hydro
    would like to know what the 9150 brought, tried to find auction results but don"t think the auction service provides them
  9. I have searched and haven't found anything, think case ih wants about $50 for a new one
  10. thanks for the replies, case ih tech came out and confirmed the pump is bad, new pump on the way.
  11. connected gauge to test port in the line after the filter and run tractor at rated rpm 2100. steering or remotes not working. tried steering steering no change in charge pressure.
  12. Thanks for the reply SDman. Checked charge pressure 19-20# at 2200 rpm oil warm but probably should have been warmer. Do have chatter in the pump and lines to filter. Cut filter open see some glitter but not much
  13. Thinking pump is bad in my 9230, no steering, remotes won't lift, checked filter in hyd tank was clean, spin on filter changed looked like oil in it has some metal particles, have to cut open filter and check yet. also need to check one way check valves in line to pump.any tips on source for pump. does caseih have rebuilt ? have hyd shop rebuild it ? tips on removal, has front steerig so access from below is very limited, looks like remove tires and work from top.
  14. Need to replace the steering cylinder bushings (bearings) on my 9230 tractor. Any advice tips or tricks I should know. Thanks in advance for any replies.
  15. Thanks for the replies. The only way the rock trap beater shaft bearings can be replaced is by taking out the beater.so the feeder house and trap have to be removed
  16. need to replace rock trap beater shaft and bearings. Do I have to take off feeder house and rock trap, or can I take wheel off on one side to get shaft pulled out, do bearings come out from inside out or from outside in. anyone done this job before? any advice is welcome. Thanks George
