I am in the process of replacing the steering clutches on my T4 and have a couple of questions/concerns. When I got it the clutches has seen a lot of moisture and they were in bad shape. The pressure plates were completely shot and one of the throw-out bearings was locked up. I decided to replace the works.... backing plates, drums, new plates, pressure plates, brake bands and throw out bearings. I got the clutch packs re-assembled and adjusted them per the measurements in the book. I re-assembled everything over the weekend and with the shafts in place the complete clutch pack can slide approx. 3/16" side to side on the shafts. Is this normal? Also, should the throw out bearing be in constant contact with the fingers on the pressure plate (mine is not)? I have not but the linkage pieces on yet between the levers and the arm on the release shaft or adjusted the brakes yet because I wasn't sure if the side to side play is normal. Thanks for any information that can be offered.
