Calendar
Everything posted by FarmallTom
Yes, and one big difference between the castings is really the reason I had to ask the question. On the 706, the PN is cast right on the left side, where there is no PN on the ‘56 casting. (at least inthat location) FT
Hello, guys. I recently bought a project 706D and discovered somewhat after the fact that it has a cracked Torque/Bell housing. My guess is that someone let their loader mounts get loose and, well... You know the rest. I have some parts machines here but nothing in a 7xx size. I do have some 856 parts tractors and was wondering if the TA housings were the same size. If so, would the entire unit be potentially usable or would there be anything that would need to be changed? TIA FT
So - I posted the video of my 706 German pulling the 4-14's above but, in fairness, I realize that the D-310 is a step up from the D-282. Here's the 560D (also D-282 diesel) that I owned previously, pulling the same plow in 2011 in some fairly hard going at a plow day. PS: I wouldn't worry about blowing a head gasket unless you're planning to turbo it. It can happen, yes, but whether or not you pull a plow isn't likely to determine whether or not that will happen. -FT
16.9's are a very nice size for a 706. 15.5.s will look dinky on a tractor that size. This is my dad, on my 706 with 16'9's, pulling a 4-14's #540: -FT
I always get ripped for saying so but I always advise caution when mounting a mid-mount loader on a 656/666/686,etc. There will probably be a bunch of people jumping in to say how they've had one on their 6xx for year with no problem but... I'm just sayin' might want to take it easy... 👍
Those 8-hole wheels were, indeed, originally used on the 706's. However, they made a re-appearance later on, when IH rolled out the 756,856 Customs. Seems like most Customs had 34's but if you wanted 38" rears, you could get 16.9's but they came on with these (presumably cheaper) 8-hole wheels. If they were stout enough for an 856, I doubt you'd have any problem with a stock 966 either. As mentioned, if there's going to be a problem, it's most likely going to be with the axle clamps, IMO. -FT
HOW TO REPLACE IH 666 BRAKE CLUTCH PEDAL SHAFT SEAL
FarmallTom replied to timothy nolt's topic in Technical IH Talk
I second what ksfarmdude said and the only thing I would add is: 1. If needed at all, this would be a great time to pull the shaft and repair any "worn in" spots where the clutch pedal rides. (you can drill & bush the pedal to match for a perfect, as-new pedal fit) 2. Whether you pull the shaft or not, make sure you clean it off well and check for burrs, etc, before you slide your seals on. -FT -
Interesting… I don’t recall that I’ve ever seen that before… or possibly I just didn’t notice. Hood the OAL’s, etc, compare? Thanks. -FT
I’m having a little trouble envisioning what you’re describing with the spacer thing. If you have opportunity, would you mind snapping a picture? TIA. -FT
On my late(r) model (1969) 656 diesel, I’ve noticed that the second battery tray is under the right side of the tank: I have another in the shop that I THINK I took off of a 656 (might’ve be a 544D though) that mounted to the left of the seat, partially on the axle: Was there a year or serial break where they changed this or was this for a 544D only or what? Seems like they544 would have used the same thing as the 656 but maybe not..?? My other question is: When did they change from the lighter weight fast hitch drawbar to the heavier one? TIA -FT
Haha! She’s a good sport and actually volunteered to ride along. (about 3hrs each way) Her rule for tractor trips is that she gets a good meal out of it. (and fast food does NOT count..! 😅) -FT
7,4xx hrs Someone did a good job on the OH b/c it starts & runs awesome. 👍 -FT
A friend of mine recently picked this little sweetie up from the original owner. For years, the only use it got was being towed behind a pickup, etc, to different bin sites to run an auger. Because of this, the steering, shift & hyd levers, etc, are all nice and tight. Seems it’s been overhauled at some time too b/c it starts and runs like a dream, with no smoke. The icing on the cake (for me, at least) is that it’s a ‘69, which is what I have endeavored to collect a set of. 👍 Needlessly to say, I knew that it was my duty to give this poor little orphan a new forever home… 😬 -FT
- 17 replies
- 18
My 826 has 18.4's and 9.5-15's on the front. I like the size pairing and, in fact, I just put new tires on the front. I also just ordered new 8x15" rims for my 706, which also has 9.5x15's on the front. They are 6 bolt and the price was either 60-something or 90-something per, depending on which offset you want/need. In my case, I wanted a 4" offset on the concave side so I needed the $90-ish ones. If you need/want pics, let me know. -FT
Aaron, I don't think I have any Custer Imp items but, when I was probably 8-9, Dad traded in his Super M for a "BIG" 706 Diesel there. (I obviously wish I knew what ever happened to the SM but that's a different story) -FT
That's exactly right on both counts. Year before last, I had to spray 3 times in order to keep the Water Hemp at bay long enough for the beans to canopy. I figure that if I can reduce that, if even by one application, I will have already paid for this rig. -FT
Given the time of year, I expect I’ll do what I can to get it ready for next year and then take it off again. ??♂️? -FT
I don't own this one anymore but it does now belong to another member here. He can chime in if he so desires... -FT
Width isn't/wasn't the issue. All the holes are in the wrong places on the '66 brackets. I'd have to drill new holes (once I calculated where they'd need to be) and also do some welding to add on and then drill even more holes in order to be able to have an appropriate amount of bolt support. Fortunately, a member here was kind enough to get me set up with not only one set, but TWO! (Thanks, Matt ? ) That's actually why I came back to this thread... I wanted to follow up, in case someone needs the info for future reference. Here's what the '06/'56 brackets should look like: (according to my setup book, I THINK they may also fit 656,666,etc when using spacers) The one with more holes in it is so that you can use it on a 1456 or 1026: And - just for the record, here is what it looks like all mounted up: Once again, I appreciate all the help offered. Thanks. -FT
I have a 1256 that someone torched the axles off of. ? I have a couple of 856 rear ends around here and am wondering if there is any difference in those axles. I realize that they are the same size, externally, but is there any difference that I might not be considering? TIA -FT
Oh, I'd probably buy another one but not for anywhere near that price. ? I gave $200 for this one. -FT
The front bracket pictured above is for the '06 & '56 series. There is a different bracket for the '66 & '86 series. Pretty sure that the correct side brackets for the '06's & '56's have extra thickness added to make up the width difference. -FT
468 is completely different. #78 had a high-mounted cross beam, unlike most of the others. This is the front mounting bracket for it. -FT
PM sent FT
Last Summer I purchased a #78 6R cultivator. Unfortunately, the seller couldn't find one of the frame rail brackets, so I set out on a hunt to find a mate. I found some that were identical but when I tried to mount it on my 706, I could not make it fit, no matter what I tried. I've been unable to find an operator's manual so I'm kind of flying blind... That said, after a LOT of screwing around, I've pretty much determined that my side brackets are for a '66/'86 series frame. (holes seem to line up fine on my 1466) Now, I'd be happy to be able to have that cultivator on about any the '06/56's or even my 656/666 but since I don't have anything to reference part numbers, I can't even tell what I need to look for. It'd also be nice to know which (if any) different series/sizes might have used the same brackets. If anyone happens to have brackets or even a manual, I could sure use a little help. TIA FT
