hardknocks
About hardknocks
  • Birthday 09/30/1968
2,736 profile views
hardknocks's Achievements
  1. It is .108 thick. And I laid it against a old clutch pack retaining ring and it matches up. I’m going to pull pto today and take a look
  2. Here are measurements it does look like pto clutch basket ring. And for previous work. I’ve had pto out this summer but no major work on rear end. Had a ta put in 3 years ago
  3. Since hytran is drained I will pull pto and take a look. Will keep you updated
  4. Is the quill that large in diameter I’ve been in those but can’t remember the size.
  5. Changing out hitch pump in a 1086. I draining all fluids and always wipe out all the hytran. When I reached my hand through the hutch pump hole and to the rear of tractor I pulled this big snap ring or half of one. So where could this have possibly been?
  6. What you mean reducer/reverser. You mean the pig tail
  7. I understand. Where u coming from on overlooking. Things it’s easy. I’ve just leaving dealer. And he’s bringing this head out. Tomorrow. I’ve fought this head. For 4 years. Had 3 mechanics and me. And father in law look. They said get rod kit. Do away with cable. So maybe this head. Will work. Im not replacing it just because of float. There is many other issues. So here is serial number. So maybe if auto float doesn’t work.I can call u direct if you willing
  8. They are not feeding in from cutter bar. And real has all fingers. And pulled back and down. Right behind the cutter bar there is a raised ledge. They are hanging on. I put pigtail on and it operators up and down but on manual. Nothing on auto.
  9. Ok I’m thinking about getting a upgrade to my head now. I’m pulling my hair out. My head is got a lot of issues besides the float.it does not feed in from cutter bar.Found a 2006 head. Will that one work on my 1688. They said it would and are willing to let me try it first. And do I still need pig tail. To make float work.If I do how do I know if I need to switch wires
  10. Yes use fleetcharge. Made just for diesels and buy it premixed so it’s right. I buy by 55gallon drum. Lot cheaper
  11. I have ordered the pigtail from case and it will be here Friday. I will tackle it again when I put the pigtail on. Thank you for all the Info this is much appreciated With all you guys knowledge I should get this fixed
  12. I’ve got voltage all the way down. 3.1volts. All the way up is 6.8 volts. How do you lower the top number
  13. Ok thank you I will try that. I just had engine running but separator or head. Was on running
  14. Ok. I have no power to plug. Been chasing wires. And I’m on right side of cab. With panel removed no mice damage there is a relay. Which I swapped out and still nothing. The three wires go into a round 14 pin connector that plugs into a black box. I’m thinking the power is coming in through the black plug Which I have no power at plug on any pin. Only power I find is coming into relay But I can’t find any coming out of relay. Now I’m stumped powe is coming in at the two red wires with green strips
  15. Ok thanks for all the input.
