Content Count
88 -
2 NeutralAbout LOFAYTX
Rank
- Birthday 07/03/1956
Website URL
ICQ
Gender
Location
La Grange, TX. 78945
313 profile views
OK, Thanks for the help
What is the purpose of this seal control knob? How do you move it? I did not want to force it. I found the control for weight adjustment that had the + and - on the lever under the left seat area.
IH 484 H pattern hard to shift in 3&4. 1&2 shift OK
LOFAYTX replied to LOFAYTX's topic in General IH
I have my 3&4 shift gear problem limbered up! It shaft was tight where it goes thru the shifter cover. Works like new thanks Guys! -
I don't know which way the oil flows into or out of the banjo fitting. When I get to work on that I will take it apart and crank engine to see which way it flows. I need to work on the shifting problem on 3&4 gear first. Thanks Guys for all your help! I think I found the parts you were talking about.
On the IH 484 I just bought it does not have any SCV remote outlets. Is there a hyd power beyond plate I can add to pipe hyd pressure to a one or two section open flow spool valve? Also where can I dump the return hyd flow back into the transmission case? I am thinking this would be cheaper that trying to get all the parts from a salvage tractor parts place.
Thanks for the help. Will report on what I find.
