maurer
Everything posted by maurer
  1. How tight should a pistion sleeve fit into the block? How do repair a loose one?
  2. the one with the yellow arrow
  3. What is the red light on the dash for? What makes it stay on? Temp, pressure, or what?
  4. maurer
    new ride
    well , we got the touring model in blue. i hope we have good luck. thank you for all your thoughts.
  5. maurer
    new ride
    what do you think of the honda cr-v , good, bad, etc ?
  6. how long should the lube light stay on in cold weather? we live in minnesota, so i mean below freezing.
  7. there is a kit a t one time to change this to a square pin , but exspinsive . other choise is to knere the pin and stack it.
  8. need a wiring diagram for a farmall h with a voltage regulator.
  9. make sure that there is no rock damage or a hole in rotor. if there is a hole get all of the dirt out. patch hole clean all dirt out from the rasp bars . now you can balance the rotor.
  10. you do not have the washer behind the spring centered so it will not go over the stem.
