andrewn269
Everything posted by andrewn269
  1. Used might be tough to find can get new thru hy-capacity, or bates corp had them at one time
  2. Spray hi tack brush on permatex number 2 in certain areas transmission assembly lube for most orings and rubber piston seals, pto clutch’s, etc and 515 (grape jelly)
  3. Looks like someone forgot to put bottom bolts in!
  4. My 966 is that way. Still has cork in top hole from factory
  5. No, but have to remember that there are different heights of fenders, so these are the correct height might have come off a c60 I really don’t know for sure but took some looking to find correct ones
  6. Yep I would say baler also but original term is hay press, maybe because even the big ones had to be hand tied?
  7. Lot of BNs around here got turned into John’s forklifts
  8. Here is video of one is 1/3 scale of original. these bales bring good money, just have to market them
  9. Has anyone built one? Have the plans just curious if anyone has any tips or tricks?
  10. Might have a wiring diagram will have to check tomorrow if I remember
  11. Dad bought it new in 79/80 not sure exactly when helper is my nephew. The dealer on the sticker is no longer in business but I had sticker made just because I worked there from 92-97 when they closed
  12. Discount hydraulic hose. Com have a Parker karry krimp and get fittings and hose from them. Can’t stock all the fittings but have a good selection of all the ones I have on most equipment, and a lot of adaptors. Very rarely can I not make a hose not work. Thanks for reminding me bout time to put an order together for spring time
  13. A piece of brake line with a bend at one end hangs on the funnel and works good
  14. Bates Corp in indiana, I’m sure they will ship
  15. I would suggest replacing rod bolts. I believe it is highly recommended to do so!
  16. Pull seat, pull seat/shifter sheet metal, remove snap ring and couple linkages, work shifter handles off, clean stuff up and emery cloth shaft, put it back together, bushings are small, can push them in with a vise. CNH is expensive for them they a standard 7/8x1x1 oillite bushing. At least I think that the size
  17. Do u disassemble it all and clean, if so hone bushings a little
  18. Send them emails! They need to hear from us. They did respond said was suppose to be up in December sent them email in November
  19. U remove this banjo fitting and it bolts in place, can see empty bolt holes in picture
  20. Been a project since last winter put on hold for summer work. Fenders off a C70, updated led lights
  21. If know what u need order from the oring store. com great service and shipping is quick,
  22. Problem external is problem gummed up on shaft that shifters ride on. Pull seat and platform and tear it apart
  23. Painted these with spray bomb and no tape! Just take ur time
