fudwayne
Everything posted by fudwayne
  1. I may be able to help you with some info and parts.
  2. After I hook up the mower I put 1 or 2 bolts in the check chain links to shorten them.
  3. Good people to work with, know there stuff. Bought several times from JP tractor
  4. I found 966 BS with old paint. No serial tag by the Hyd. filter or bell housing, has rivet holes in the bell. How can I get the year? did they have casting dates or something?
  5. The IH dealer I worked for in the 70's used all Bobs Grinding and was good stuff. He used a grey hound bus for deliveries. I think he may have had some tax issues.
  6. Anyone seen or have a Farmall - Utility 404 with diff lock, has a right side pedal pushed by your heel.
  7. May be worn distributor shaft to get the odd cylinders
  8. I would like to see a serial number list for the B 275. i have S/n 20062 its a Hi Utility with 38'' rear tires
  9. Did IH put black stripes on any Yellow Industrial tractors ?
  10. Never noticed the 544 leak before it was on a tractor ride. Has any one used the breathable dipstick?
  11. On a Farmall 544 gear drive, after a road trip appears to have oil leaking from the breather on the top left side of the trans cover. Any one else seen this and have a cure
  12. The 404 rear housing is nearly the same, but it has a 2 piece top cover and the 3 pt. hyd.
  13. Anyone know the s/n of the first 966 Hydro built, have a local tractor with a real early s/n
  14. I have 8 weights and bracket like the bottom set 608 335 6218 WI
  15. send me your phone # I will try to get you a picture of mine that needs a little work
  16. sounds like possibly the pilot bearing in front of the clutch, first thing try to tighten the bolts holding the center section to the rear end.
  17. A farm sale with all nice equipment. F1256 AWD= $20000. F856 w/f nice original= $9500. F826 w/f = $7050. F656 gas hydro= $5900. M with V-8 383= $4600. F460 w/f gas= $2000. M= $1350 & 2200. 424 with ldr= $3100. Front Weights REAL HIGH
  18. Nice Collection. How many''International'' brand ?
  19. Last week 1/14/21 a 966 BS sold on a On Line estate auction at Reedsburg WI. for $16000. Did I miss something special on this farm tractor.
  20. Father in law was friends with a Draeger south of Waterloo WI
