jeff311
Everything posted by jeff311
  1. email me at jeffsbigdawg@gmail.com. I make this 10 hoile weight bracket that fits a 340U, 460U, 460HU, 504U and 606. These are heavy duty weight racks based off the original that you see in the parts manual. I don't have the IH number handy with me but, these brackets attach to the side of the front bolster and wrap all the way around the front. Holds 10 IH suitcase weights. I can email you a pic. Jeff Foreman THAT EMBLEM GUY 317-379-7435
  2. The 383 used a 4 cylinder Nissan diesel engine the SD23. The 274/284 used a 3 cylinder SD16. A Scout pickup used the 6 cylinder SD33 Nissan diesel engine. Basically the same internal engine components per cylinder, just added more cylinders as the engine grew form 3 to 4 and 4 to 6 cylinders. Lots of these SD23 engine parts in Asia and EU. NICE restoration
  3. Yeah, I don't mind that I'm missing one International emblem that was found on about 15,000 tractors from this era and the 2 emblems that were only made for a handful of tractors in this series are both in my possession. Now that this tractor is on display with a "rare" label, it will be fun to see how many more come to the surface. I still do not believe there were more than 10 made and that could be way too high. Time will tell.
  4. Well, It's here. Now the fun begins. Serial 16373. Runs and drives but, has some issues like they all do. Needs a T/A and clutch for sure. We will take it down and go through it like it should be done. Our last two International Hi-Clears were a 606 Diesel HC in 2013 and 606 gas HC in 2014. Just about the same tractor except a 4 cylinder LP engine. Both of those took up about 350 sq ft of Devon's shop floor space when we got them tore down. This one will finish out like those two with upgrades to rear spin-out's and dual hydraulics. As I did my walk around today, I thought although it looks pretty tough, this one is in better shape that the two 606's were when we started with them. Pulled this one out of Unadilla NY. The 606 gas HC came from NW of Philly and the 606 Diesel was found hear Hartford, Ct. Now sure why all these rare International Hi-Clears from the mid 60's are common to the upper east coast but, they are all within a 200 mile radius of NYC. This one is 1 of 3 that I know of in the USA with this engine and the Hi-Clear International chassis. Production numbers are uncertain but, this series was after the 460 LPG HU and they only made 13 of those. The 504's were not as popular as the 460's so, my guess is IH made less 504 LPG HC. That will be a fun investigation. More photos as we get the gal undressed and apart.
  5. Cody, Check you Personal Mail. I can help with more info, parts and a buyer if you need assistance. 317-984-3698 or 317-379-7435 Jeff
  6. I think you have an issue with #5 valve timing. Could be a bad cam lobe, scored lifter bore and/or lifter, bent push rod (check them all for same length), broken valve spring or keeper, or possible faulty distributor cap. Best luck on the investigation. This does suck after all you have done this one to ensure a proper professional rebuild.
  7. Is this the one you are looking for? Call me evenings at 317-984-3698 for further discussions. This one is a composite replica of the original metal stamped emblem. Jeff
  8. TP
    I have 2 Diesel 284's. One is 2wd, one is 4wd like yours. Need to get both of them new air cleaner filters. Love the way you did yours back in Feb. Would you be interested in making more of those thread extenders? I need two and I'll bet they would sell good as a conversion kit for all they guys out there that want to get away from the expensive IH Jap filter route. As you may know, I'm THAT EMBLEM GUY and have some marketing history. Your little extender could save may guys some big dough if you want to do the work and get some "mailbox money".
    Let me know your thoughts.
    Jeff in INDY
    1. TP from Central PA
      TP from Central PA
      I could make more, that tractor isn't mine, it is actually another members on here.  Let me know how many your thinking.  I will have to see when I can steal it back to see what I did, sort of forget to be honest.
      Let me know,
      tntwrenchheads@aol.com
      tyler plocinski
      TNT Repair and Service
      570-447-5839
  9. Wayne, There is a 350 International Utility LP being parted on ebay right now. The guy has the Western tank for sale this week. It is part #365788R91 according to the photo on ebay. You might want to check this one out. Not the exact same as a 404 but, I'll bet it's real close. Search "1957 International tractor 350 tank" on ebay. Jeff Foreman
