Content Count
1,727 -
Calendar
Everything posted by czech
Was the BD 264 & the BG-265 mechanically the same engine?
Does anyone know if there are any of the 1961 - 1968 pickup trucks with the IH D-301 6 cylinder diesel still driving around? Also what years were they offered with the diesel?
Any of you shotgun shell reloaders know why there are no primers available? Not even Factory shells are available!!
Seems like some years back I remember reading about a guy who special ordered a new pickup with a 6 cylinder D-301 diesel!?? Anybody??
Model: 18TDR. What does the "R" designate if anything?
Gasoline with ethanol will ruin any rubber gaskets in the carb. The exhaust valve seat are designed for lead in the gasoline. The exhaust seats will burn if ran for an extended length of time. When lead was taken out of gasoline, the exhaust seats had stellte seats installed in subsequent engines.
Tighten the head bolts starting with 100 lbs, 175 & 250.
Is the SD-240 & the BG-241 the same engine also the BD264 & the BG-265 the same engine?
The first TD8E was 5001. What is 902U1582?
Can anyone date this serial number on a TD9? TDCB18543T4. 18543 is the serial #? What does thew T4 mean?
Was the 105 combine made in Hamilton, Ontario, Canada as well as East Moline?
It has a detent ball? That would make sense?
A B-25 & a B-17 bomber at the Lone Star Flight Museum at Ellington AFB in Houston are being retired from active duty. The last rides given were on January 25, 2020.
My PTO jumps out or gear. What would cause this? I looked at a parts schematic and I can't figure out what holds it in gear?
I dug out my timing light and dwell meter. Dusted them off and put a set of points (Blue Streak) and a condenser in my 1965 V8 326 Pontiac Tempest. The only hard part was having to crawl over the engine compartment to install the points. My arms must have shrunk or my belly got larger!!
IH construction equipment serial numbers & engine xrefs
czech replied to M Diesel's topic in IH Construction Equipment
Will you one day include the TD6 & earlier models? TracTractor etc. -
I have never seen a 4156. It has one of my favorite IH engines. The DT429. The 429 was also in the TD20B. Overhauled a few that were the TD20B. The only trouble I remember was the "wet sleeves" leaking coolant into the crankcase. Seems to me that it was kind of a "step-child" engine. IH didn't seem to like it much. I thought it was a rugged dependable engine.
190 pages, 66000+ viewings. This must be some kind or record???
