soupkid
soupkid's Achievements
  1. Startup Draw (First 4–5 minutes): ~2.5 Amps (300 Watts at 120V). "Our pellet grills draw about 2.5 amps during startup as the grill heats up..." -- [Traeger Support via Home Depot]. The extra power is required because the electric hot rod is glowing red hot to ignite the wood pellets.Running Draw (Normal operation): 0.4 to 0.8 Amps (roughly 50 Watts at 120V). Once the fire is lit, the hot rod shuts off. The grill only uses minimal power to occasionally spin the auger and run the draft induction fan.
  2. I've always used diesel for hornets nests.
  3. Did you Try an impact ?
  4. What is a Heim style ?
  5. I'm looking for the 4 ball joint ends on the shifters and the bushings, H pattern. CIH says discontinued for everything. CIH parts online doesn't give much detail on the parts. The 2 on the top of the transmission are the same and the 2 on the side are the same, same bushings for both levers. CIH list what other equipment uses the same part. The ones i checked ate also discontinued. other problem is the tractor is almost 3 hrs away. If I knew the size and stuff I could likely source some. Any idea where I can get some ?.
  6. Great suggestions and I appreciate it but I'm in Canada, Ontario specifically so most of the options you suggest to me are a no go. I will try the local case industrial dealer
  7. I'm in a bit of a pinch and need hydraulic oil for my 484 and the tractor is a hundred miles away along with the manuals for it. I have no case/IH dealer anywhere near me. What spec do I need for the oil ?
  8. Ill look in my manuals ti see if they show that pattern.
  9. It started right up after being parked since last November. Im still try to figure out the fuel enricher/choke on it.
      • 1
      • Like
  10. 7/8 " bolt, long shaft flat screwdriver among other things. Lots of screws and nails. One tire on my dump trailer has 7 plugs in it, expecting it to blow apart anytime.
  11. Im up on northern Ontario, Sudbury to be exact. Listened is a 5 hr dr one way for me.
  12. I paid $800 + for my last snowmobile helmet.
  13. All helmets need/should be replaced 5 hrs after mfg date. The mfg date sould be on a Tage somewhere inside the helmet.
  14. We are paying about $7.53 a us gallon. I converted our 1.99/l to $/usg
  15. I bought 2 bulbs for a 284 i had from IH, over $70 a bulb !!
