ny hay farmer
ny hay farmer's Achievements
  1. how about a birds nest on intake side of air filter, happened on a 1086 to me is the advance working in the distributor, dont forget to goto parts store and get some lead substitute and put in gas
  2. send a back pic, I have one does fertilizer, and lyme, I ll send you a pic
  3. they will come in the new gasket kit, if not I have them in stock
  4. on my 686, the seal blew out,behind the gear, new pump fixed the wine, fyi
  5. will you let me know what they sell for, if you go?, I can't attend
  6. injection pumps should be the same, probably have different fuel settings, and different tourqe curves,
  7. guys just did a 1066 $1700 in complete head done, and reconditioned the rods $1400 in sleeve, piston s, cam, lifters, gaskets, new head bolts, oil pump and drive gear, water pump $1000 in turbo TO 4, sleeve, and 90 bend $700 injectors rebuilt, and I did all the labor, this is a inframe also, clutch and I pto , new radiator done last year
  8. buy it, or send it to ny, we d take it for$8500, lol
  9. looking 4 info, 414 heads, turbo, virus non turbo , I know they will bolt up, but are there any difference s, in the compression, or chambers
  10. I support what you guys r saying, little more fuel, and a dyno, mine makes 147 hp, all day
  11. someone always steps on my diff lock, and it only pops back 1/2 way, and chatters, pull it up with your fingers. noise goes away, if your that lucky
  12. thanks, guys
  13. it won't freeze, there is rubber under canopy arms, nothing in tubes yet
  14. does anyone have any thoughts on how to quite all the gear noise, on 66 series tractor s w rops? I ve heard a few, install rubber balls in tubes, spray foam, and windshield washer fluid, to dull the noise, anyone ever done it or seen it ? thanks
