Hello all, recently purchased a 3788 on an auction and wasn't able to drive tractor beforehand. I got the tractor shipped home and went to drive it and it felt like the steering pump was starving for oil and wasn't pumping any fluid. The steering wheel is hard to turn but the tractor does steer at an idle but at higher RPM's I lose almost all steering and can't hardly turn the steering wheel at all. I changed the hydraulic filter on the right side of the transmission but it didn't help much. Wondering if there is another hydraulic filter I can change? Also there is water in the hydraulic oil but I don't want to change until it drives or until I am changing the steering pump or something since oil is so expensive and I am not sure if thing could be the problem? The steering pump seems to whine or chatter pretty bad while the tractor is running but I don't know if this is normal or not. I don't know if it may be related at all, but the clutch seems to randomly disengage when I am driving it and then instantly reengages and gives the tractor a huge jerk. When this happens the trans lube light comes on so I think that would be the clutch? I am trying to figure out what the problems are before I go carelessly throwing money at the thing. Lucky for me, the TA, pivot pins, tires, and motor all seem to be fine, the transmission shifts pretty good, and besides the issue while driving, the clutch seems to engage fine from a standstill. I am hoping that this is the right place to find help since I don't really know a lot about these 2+2s. Thanks, Archer
