My two cents , that tractor can go to 200. this depends a lot on how and who operates this tractor. If you throw it in gear (pto) under a load and use full throttle doing so etc. you will throw parts on the ground no matter the hp. If you are in hilly ground and get the EGT to hot you will have damage. If you are careful and bring in power slowly and run it easy shouldn't have any issues. I had a c-15 cat in my peterbilt which was putting out 775 at flywheel with light duty clutch and 13 speed. no problems ever because I was the only one using it. Every mechanic told me I would throw them on the ground, had over 500k miles on that setup when I sold it. Same with tractors our 1086 had 155 and never had a problem
