Jack Tibbetts
About Jack Tibbetts
  • Birthday 07/09/1956
    Bassett Viirginia
    boating motorcycles currently restoring 1968 1200c international truck. almost forgot red tractors.
  • Yahoo
    jackt24055@yahoo.com
86 profile views
Jack Tibbetts's Achievements
  1. Im sure your right. This is the first International Ive owned. Im still learning about them.
  2. I ran that 20572 number again and it comes back to fit a 266ci 304ci engine. But not the 345 or 392.
  3. I got upper radiator hose today . invoice says hose fits 266 304 345 392 v8 engines. invoice says for 1966-68 a b c series. trucks. 34.95 for hose 24.57 shipping . IH parts America.com . their part number is sl322614c1. Hose has no markings at all as far as mfg. or part number but its the correct hose . Thanks just wanted to pass info along incase anybody was needing one.
  4. Just wanted to add both of those hoses are made by Dayco. Both were purchased at Rock Auto. I think like 17 dollars for both.
  5. I will post the part number for the upper radiator hose when i receive it. I checked out as a guest and cant access an account. To look up number. But i have got the bypass hose and lower hose . part numbers are Lower radiator hose 70603 made by Dayco. By pass hose A70924. Both made in USA. Upper hose should be here in a day or so. Ill post part number when i get it. All these hoses should fit engines from a 304ci to a 392ci.
  6. Thanks I went on binder boneyard site . They had a few parts i was looking for. would like to have them upgrade my suspension as they do all that fabrication work. but too far away. 2600 miles from my location. A lot of spring shops have shut down .
  7. I ordered upper radiator hose today from old international truck parts web site. And ordered a nos radiator shroud from Reous brothers in Missouri. Thankyou for all your help with my search.
  8. Thanks. The more sources i have the better. Sure would have been easier to restore a ford or chevy. But only would have half the truck this one is. Hee Hee.
  9. I can .but the way it works is the radiator from the factory bolted to the shroud. and the shroud bolts to the truck. if i cant find a shroud ill have to make a bracket.Im going to contact Roedel brothers in missouri today.They had a nos on there web site for 129.00. but it might be off a scout.Im going to ask them if they have an upper radiator hose also. Or know the part number. thanks.
  10. Hi everybody.Does anyone have a 1961 to 1968 pickup radiator shroud for sale. I dont know if they are all the same but I have a 345 ci engine.Thanks.
  11. Thanks .I know if I had the part number I can find one.
  12. To lightning boy. I do not know the original part number for that hose. or even a gates number. The hose that i took off was not the right hose. Probably because last owner could not find one. Thanks.
  13. Hello and thank you for responding to my post. The Gates hose part number 20572 fits all International engines six cylinder up to the 304 c i eight cylinder. Unfortunately it wont fit the big block 345 c i. I might have to buy one of the custom hose making kits . But they are a little pricey. About a hundred dollars. As many 345 engines out there you would think it would still be available. But thanks again i appreciate it. Jack.
  14. Hello and thank you for responding to my post. The Gates hose part number 20572 fits all International engines six cylinder up to the 304 c i eight cylinder. Unfortunately it wont fit the big block 345 c i. I might have to buy one of the custom hose making kits . But they are a little pricey. About a hundred dollars. As many 345 engines out there you would think it would still be available. But thanks again i appreciate it. Jack.
  15. Hi .I have a 345 ci engine in my 1200c pick up. I cant find a upper radiator hose. I have found the lower and bypass hoses. Any ideas where i can buy one. Thanks.
