Gender
Location
Montana / Indiana
Interests
Chainsaws, Timber Framing, Forestry, Heavy Equipment, Ya know, the usual.
Koot Kraftsman's Achievements
1974 International TD-8E, looking for Info
Koot Kraftsman replied to Koot Kraftsman's topic in IH Construction Equipment
Got both cylinders rebuilt, re-installed and greased to the hilt... they leak all over the place. Just kidding, the C3 seal kit worked and everything operates smoothly with no leaks at all, not even the cylinder with the dent. Of course only time will tell how long they will hold up but I'm satisfied for now. So for a 74 TD-8E the 626230C3 kit is good! Now it's on to really put her through the paces and see what's what. π -
I understand what all the parts in the kit are, they just don't match up with what I took out of there. I fear the rod seal (the one that goes in the middle of the bore) is incorrect but I've been wrong before. The part numbers are all correct or at least match what the book calls for so I'm going to install both seal kits and see what happens. -
Ok, got the seals... strike 2. The C3 kit looks identical to the C6 kit. Neither kit has the inner shaft seal. I'm beginning to think somewhere along the line, a previous owner put cylinders on there from a different machine or some kind of generic/universal cylinder??? I don't know... I'm spitballing now. When I opened up the package the seals came in and looked at them I got pretty irritated as you might imagine so I started looking at the cylinders for some kind of Identifying numbers and all I could find on them was "824". I started trying to find something out about them and came up with nothing solid. This is apparently past my knowledge base so tomorrow I'm gonna hit up the nearest hydraulic shop and see what they can tell me. π€¦ββοΈ Frustrating -
Sorta good news (maybe)... I found the part number in the parts manual (albeit printed in 1980), it calls for 626230c3 (vs ...c6), looking at all the crappy photos online, the kit looks more correct/promising. Returned the c6 kits and ordered c3 kits from the same company and crossing my fingers ππ€. Better news is that the c3 kits were half the price of the c6 kits. I'll definitely report back the result... no doubt I'm not the first, nor the last to deal with this issue, hopefully helps future readers. -
Even harder when what you pull out disintegrates. Thanks for the advise though, hadn't thought of finding. hyd shop. The nearest one would likely be in Louisville which is over an hour away but if the trip has a promising outcome it may be not just the best way, but the only way, to get this all sorted out. -
I agree it sounds logical, only the C6 kit is clearly incorrect and won't work. I'm thinking maybe the earlier units (mine being toward the end of the 1974 build year) had a different cylinder head than the models that came out later and requires a different kit. The only other explanation I can think of is that a previous owner swapped out cylinders from something other than a TD-8E?? If you've done this job before, do the guts look the same as what you had? The parts in the book don't even match what comes in the C6 kit though so... π€¦ββοΈ . Will continue trying to make sense of this but if someone has experience with this, i'd love to hear your thoughts. -
A few more photos of the cylinder to help identify the seal kit I need. If anyone has done this work to a cylinder same as this one, please share the kit part number. I am told by one of my parts guys that he's showing a 626230C5 (vs 626230C6 that I ordered and what's in the photos.) -
The cylinder bodies survived on mine thank goodness however, upon inspection of the cylinder I have torn apart, the side of it (right in the middle) was smacked at some point in its life and gave it a small dent. I'm preparing myself for the possibility of a new cylinder if this seal kit either doesn't work, or more likely, fails prematurely but for now I will continue with the seal swap. Worst case scenario I see is that it fails again and I have to make the decision whether or not to just buy a new cylinder and I'm out the price of the seal kit, best case scenario this fixes the leak and I don't have to worry about it for a long while. You can tell these seals/rings are SUPER old as they are just falling apart as I try to remove each piece. The oil seal itself is being a bear (need to get me a new seal puller) and at first I thought the last guy to replace these put the oil seal in backwards but as I read the manual, it says "the oil seal must be facing out". Every oil seal I've installed in my life has been with the cavity facing the oil to which it is holding back...what the heck?????????? To add to the misery, the kit I bought must be the wrong one, I bought IH-626230C6 and although the parts all look correct for the piston and the outside of the cylinder head, the parts for the inside of the cylinder head do not look right. I could be proven wrong but I don not see the parts I am expecting to see and they don't look like the remnants that I'm picking out, not to mention that there are pieces in the seal kit that are definitely not on this cylinder, I was thinking since the seals are used for many different cylinder models that not all the parts would be used on all cylinders but this is my first seal job so I just spitballing here. Interestingly, the rod lock nut on the end of the piston rod was backed off by hand! it was only hand tight... whew! Dodged a bullet there The machine is a 1974 (serial number 4420009U005505) with inside arms (6-way). I am replacing the seals on both of the angle cylinders. Did I order the wrong seal kit? Does anyone have the correct seal kit part number or maybe I have the right kit but I'm just looking at it wrong, I suppose that's possible too. -
Double pipe wrenches with 10' snipe each is what it took to bust 'em loose... time for the fun to begin. -
Pipe wrenches is what I'll have Dave, I'd love to use the "right" tool (and I tried with my spanner but it failed). I plan to use double pipe wrenches to give equal torque to both sides like a tap handle or, well, any other T-wrench. Best I can do with what I have available. -
Now that there is some Gucci tooling! I'll have to put that on my Christmas list. -
ππ» πͺπΌπ§ -
I was re-reading the cylinder repair directions in the manuals and where it refers to torque for the piston nut it speaks of "type 8, phe coated at 330-370 ft lbs" OR "type 5 cad. coated at 450-500 ft lbs". How would I know which one my machine has? Will it be blatantly obvious when I get in there, like it says it right on the nut? Also, the retaining ring is 600-650 ft lbs of torque... I don't know of any tool that could accurately measure torque applied to the retaining ring, at least not one the general public would have. BTW, the manual states to use a "spanner or chain wrench" for removal of the retaining ring. Since I'm guessing most people don't have spanner or chain wrenches capable of measuring torque at all, never mind 600 ft lbs or even a regular torque wrench capable of reading 330 ft lbs (although this would be much more common in shops that people like you and I run out of) is the consensus just to use common sense and torque the crap out of it? My impact wrench has a max torque of 700 ft lbs, so I could use my biggest regular torque wrench that goes up to 250 ft lbs and use the impact to get the other 80 maybe using the mid setting, I'll have to look into that. But when it comes to the retaining ring, outside of tightening the dog crap out of it and guessing, the best I can come up with is to mark the depth on the threads where the retaining ring is currently at then make witness marks across both the ring and the cylinder along it's axis and crank it on until everything lines back up to where it is currently torqued to. I know that's not the perfect solution but will at least get me way closer than guessing. Thoughts?? -
I did leave it attached to the machine, it's the logical solution to a solid mount. Dave, you're right, metal is everywhere and I could find some pretty easily no doubt but I don't exactly live near town so I line everything up with my trips to town. I've been in and around metal shops and fabricating tools for decades and I agree, a good welder is a good investment... I just sold off all my nice welders a few months ago as they are stand alone units requiring 220 power. I have been looking into a good generator welder because that is what I'll be needing where I'm going, the nearest power source to my Montana home is a 45 minute drive (I'm out there) and will likely just wait to buy one there, one less big item I have to haul up there.
