Coldaniel
    1
About Coldaniel
  1. How is the rod going through the engine that apparently opens the gas/sparkplug chambers interconnected tothe carbeurator shut off valve in the space between the engine block and the carbeurator? I have good gas flow into the carbeurator as shown by opening the drain valve, and the valve into the plug area is opening as proved by the added compression when the compression release lever is closed. Can't see how the rod coming through the engine is connected to the shut off valve in carbeurator. Can feel and see the spring, but not the connection. Is there a print showing this? The tractor s
