int 504
Posts posted by int 504
I don't see the left rear tire and wheel ????
My 1945 A has a cast knob also. WW ll production change. Rubber was short.
They came up with something called a beaver deceiver somewhere around here. It's supposed to work good.
1 hour ago, Lazy WP said:
Volvo is probably a decent truck for that application. Pre 08, I think, is pre-emissions. Make sure it comes with the proper ppe. Shorts, flip flops and foot rest on the dash.
Seems like there should be some crocs.
1
1
Try the construction forum as TD's are the same. TD9 perhaps.
My plain jane 1970 F150 240 6 and a 3 spd got 20 mpg or better loaded or empty. No power anything. Got a 68 later with 302 and power steering was easier to get around with and faster but down around 16-18 mpg.
2 minutes ago, TRAVELETTE said:
It appears that he refers to anti-seize compound as never seize.
That is what I call it as that is what it used to say on the can way back whenever.
1
Brain wave scanner.
1
The boat is now in position for that.
2
1 hour ago, acem said:
Maybe a girlfriend half your age would perk you up?
Or wear you out.
2
Not thick enough to take any off and can mess up geometry of clutch release apparatus. I did a Wrangler clutch for a family member a few years ago. The machine shop resurfaced on rotary broach and we shimmed back to original position. Still working good but a replacement stock grade wheel might have been less $$$ or not much more. They can also be done on brake lathes but I'm not sure I'm brave enough for that as I don't know about accuracy. If you are talking aftermarket hi po parts then this advice may not apply.
1
I don't think they recommend resurfacing those flywheels.
1
3 minutes ago, brahamfireman said:
No......
Not all accidents involve hitting another vehicle. Crumple zones protect the occupants of the vehicle from the sudden change in speed a vehicle experiences in a crash.
I agree on a front crumple zone but I have seen numerous accidents where a car ran into the rear of a 3/4 or 1 ton truck. The car was demolished and the truck and occupant(s) drove away. With belts in use of course.
I'm guessing the crumple zone is to protect the car that runs into the truck.
2
McMaster Carr perhaps.
2
"If brains were dynamite he wouldn't have enough to blow his nose."
He is a waste of shoe leather.
I have used a on/off electric water heater for s sink for many years. I'm currently on my third one. The rise/gallons thing is anb issue that I work around with a ball valve to adjust the output flow. Full on in the warm weather reduce flow to maintain temp when cold. You may find a gas or fuel oil better suits your needs.
12 hours ago, Dasnake said:
If it ain't broke, beat the living shiit out of it until it is.
Two wrongs don't make a right, but two rights make a u-turn.
Actions speak louder than words, especially in a library.
If it ain't broke don't fix it. maybe two rights and a left for a u turn.
1 minute ago, cobfly said:
That guy is so stupid, he couldn't pour sand out of his boots, if the instructions were written on the bottom.
I've heard that but it was #iss rather than sand.
2
The proper lot identification also.
1
Looks like an upside down boat hull.
1
The John Deere had a diverter valve which transferred hyd pressure from the rockshaft to the hyd cylinder hooked to the upper arm linkage on the hitch mimicking a 3 pt and rotating the implement and maintaining constant draft and traction according to their advertising. A 3 pt with draft control seems simpler. Draft control on my 504 works.
1
On 4/3/2023 at 9:47 AM, jeeper61 said:
In my dreams I see a tilt deck with a hydraulic winch
Either powered off a truck PTO or a gas engine hydro pack on the trailer
Some people use the power steering pump on the truck to run the winch.
Mower deck treatment
in General Chat
Posted
My Bolens mower decks have a fitting for a garden hose in the top. Turn on water, start mower, run until no grass comes out chute. Works good.
