timothy nolt
285 profile views
timothy nolt's Achievements
  1. thats what it took to get it out thanks for all the replys
  2. i tried to pull it but i cant i can get the brake pedal side but i cant get the key removed buy the clutch pedal
  3. I NEED TO REPLACE THE SEALS ON MY BRAKE CLUTCH PEDAL ANY IDEAS ??
  4. i just replaced all the rockers now they get oil
  5. as far as i know they are the same except maybe the engine
  6. does anybody know the part number for the rocker arm bushings ??
  7. so i took it all apart and some of the bushings are worn out does someone know where to get new bushings
  8. i think some of mine are a little looser then the others which leads to losing all my oil so i,ll probably end up buying a used set on ebay
  9. i tried trie state ih but they wern't able to help
  10. this part number should help somone when they go to order it
  11. if i move the rocker arm aside and crank the engine over i get oil out of the 2 holes thats what has me stumped
  12. should i just buy a differnt rocker assembly or what do you guys think ???
  13. my project ih 666 swapped dt360 was making problems it wor a push rod down now i got a new one through smith bros the n i figered out some of my rockers arn't getting oil any help appreceated ??
  14. so i got my new push rod from smith bros but now some of my rockers arn't getting oil i also got 1 extra pushrod if someone needs 1
  15. can someone help me out i.m in a fix and i need my tractor any replies appreceated
