actualLocke
actualLocke's Achievements
Newbie (1/3)
1
  1. Service tech just left. The left hydro is shot. When I pulled it out of the shed for the tech, the front right and left rear tires spun. Which sounds opposite of what it should act like when the left hydro goes out. But I guess because the left hydro is out, all the oil from the charge pumps is going there, starving the right hydro of oil. And the reason the product pump was quitting, is because I was using the "oh sh*t" pedal (as the tech put it) when I was going around telephone poles. ? I guess when you hit the brake pedal it shuts down everything except the engine.
  2. So if I'm understanding this correctly, the gear pump on the left side hydro, only runs the product pump. Therefore the right side gear pump runs the charge pressure for both hydros?
  3. I don't know if it all happened instantaneously, or progressively worse in the space of an hour. I guess we'll see what they find in the morning.
  4. I have a 2005 4410 sprayer with just over 5k hours. Previous owner said one hydrostatic pump has been replaced (not sure which one). Today I started noticing some wonky things, I'll list them in the order I noticed them in. Also the dealer is coming out Monday to diagnose the problem. I figured I'd post it on here and see if any had any thoughts, or if nothing else I'll post what we figure out to help someone else out. (this all started happening when I was nearing the end of my load, so the sprayer was hot) #1 I noticed the chemical pump stopping and starting again when stopping and starting driving. (mph, not rpm) #2 Then I noticed the sprayer being pretty sluggish when using the hydrostatic lever. I was working around poles so I was doing a lot of starting and stopping. It felt kinda like I was spinning out, but I wasn't. And with the speed pot at it's minimum, and the lever at it's maximum, where I used to get 9mph (if I remember right) now I was only getting 4-8mph. (Sometimes 4 sometimes 6 ext,) #3 I switched fields and noticed I was only getting 26mph, and slowly work it's way up to 29. Where before it was 32 bang on everytime. #4 With the engine idling, the ladder won't quite raise all the way. But as soon as you rev the engine it'll come right up. Which speaking of the ladder, the ladder does not fail the "real" ladder test. (Pot speed 100%, rolling at 5mph, go full speed with the hydrostat lever, the ladder doesn't move at all.) The sprayer on the other hand takes an eternity to reach full speed. (or 29mph) I did notice however, when I was rinsing the tank. That when I do the ladder test with chemical pump on, the pump pressure will drop down to 15 or 20psi. Unable to stay where I put it. We used a infrared thermometer on what I think was the case drain on the wheel motors. The dealer said if the swash plate is messed up it'll bypass a lot more fluid. They were all within 10°(F) though. We're kind of suspecting the left side charge pump. Because from following lines it looks like that's what runs the chemical pump and maybe the ladder? Couldn't quite tell though. But honestly nothing quite makes sense to me.
