GaryK
GaryK's Achievements
58
Did you try a different pump supplier?
I suggest getting a whole new dipstick. Over the years metal fatigue develops from taking it in and out and they do break. Many years ago had to drop the oil pan on a 1066 to get the broken piece out.
Quick internet search shows this: All Mini Tractor Parts You Are Looking For | TracPartz TracPartz is 100% independent and can therefore deliver the highest quality for the best price. Our certified suppliers supply OEM quality parts with which we guarantee a long life! Mini tractor parts for all brands. Mini tractor parts for all well-known Japanese brands can be found at TracPartz in our webshop. The range of mini tractor parts knows no limits, from filterset to head gasket. TracPartz supplies both private individuals and mechanization companies. https://www.tracpartz.com Was this helpful? Trac 4 Inc 102 S Water St, Wilmington, IL 60481 - YP.com https://www.yellowpages.com/wilmington-il/mip/trac-4-inc-2406785 Tractor Equipment Trac 4 Inc Trac 4 Inc (815) 476-5538 102 S Water St Wilmington, IL 60481 Map & Directions Tractor Equipment & Parts Be the first to review! Add Hours 39 YEARS IN BUSINESS Add Website Suggest an Edit Is this your business? Customize this page. Claim this business More Info Gallery Reviews Hours Elwood · Braidwood · Hay · Coal City · Fish Hatcheries · Horse Trailers
They can get rusted and sturck real tight over the years. For our late dad's 1066 we had to torch it around the bolt a year ago. Than still had to drive the one half out. It was a three hur job. Probably way there is no problem getting replacement ones!! Using a big powerfull impact at times just makes things tigher and harder to get loose! Several years ago on the other side the bolt actually bent between the halves. Didn't have anti-seige years ago either.
901 White will need to be mixed at an auto parts shop. Case IH no longer suppling
I put this part # on my search engine. Results show some dealers have 1 in stock.
When I am looking for parts, I go to "Tractor House" and do a part search. I did this with the part # you listed. One in Canada. Good luck.
IH 1066 open station purchased new 3/31/72
INTERNATIONAL HARVESTER at work on the farm pictures!
GaryK replied to INTERNATIONAL 1466's topic in General Chat
I had the 3 cushion seat from our late dad's 1066 redone by an upholstry shop. Needded the foam also. Nice thing was could select the seat materail to use plus a color pattern. I had the frames sandblasted and painted by a friend of mine. Came out very nice just had to wait some. You may want to look at tractorseats.com
Make sure you get the lines correct. If not the oil won't flow.
Used my brothers Super MTA at a plow day last May.
I got a couple of cans of 901 from Carquest this past summer. Any auto store should be able to find the 901 code receipt and mix for you
1st place pull!!
I do.
