Seven9
    1
About Seven9
  1. I had a similar issue with worn out drums on an R or S-100 axle I rebuilt to use in my L-120. It was a Dana 44 5x4.5 bolt pattern (Ford). I ended up using drums intended for a 55-56 Thunderbird and Raybestos 55PG shoes. I bought them from larrystbird.com and they are expensive. Because the axle length was not quite the same I had to use .060 shims between the hub and shoe to prevent the shoes from wedging against the sides of the drums. The drums are not hub centric either and I had to open up the center hole to fit over the hub. If I had to do it again I might get the rear disc setup that TSM
