OhioBob2020
    13
4 Neutral
About OhioBob2020
  1. I dropped the pan and the oil pump plate was warped I replaced it now have 50lbs cold and 35 lbs warm at idle. I checked price for new pump cheapest I could find $ 1185.00 also it only has 1 replaceable cam bearing Front bearing is all that I can find listed. thanks for the help.
  2. Thanks I dropped the pan and checked the oil pump plate it was warped I got a new one and now have 35 lbs at idle warm.I kinda felt the same way about some of the comments. I just wanted help not a lecture THANKS AGAIN!
  3. sleeves pistons main bearings rod bearings that come in the complete over haul kit. Thats why I said complete over haul
  4. I put new thrust bearings and sleeve and drive bearing in it Thanks
  5. Thanks The oil pressure doesn't drop below 15 lbs I'll check the pump first.
  6. Thanks for the infor I'll keep checking to see if I can get it fixed.I don't use it much so I hate to put more money into it THANKS!
  7. Yes I did use the old pump but put a new regulator spring and gasket in it
  8. Oil pressure drop even after complete overhaul I have a 504 international utility that I complete overhauled the engine and oil pump new spring. It has 45 lbs pressure on cold start up then slowly drops to about 15 lbs after running for about 1/2 hr.Any ideas what would be the cause. It has 30 w oil in it.The engine in it now is a C135 The engine was replaced after the other one blew up.Thanks for any help you can give me.
  9. I have a 504 international utility that I completely rebuilt the engine and oil pump new spring. It has 45 lbs pressure on cold start up then slowly drops to about 15 lbs after running for about 1/2 hr.Any ideas what would be the cause. It has 30 w oil in it.The engine in it now is a C135 The engine was replaced after the other one blew up.Thanks for any help you can give me.
