Gender
Location
Northern IL
Interests
Tractors H, NH TC29, CIH40 FEL (CIH495 sold) , CIH 885wCab, 2255FEL, CIH 5120 cab 510 FEL, White 2-30
NH balers 311,570, 658 (round Baler) Plows Ford 2 btm, Ford 3 btm, IH 535,710 IH 10’ wheel disc, Pottenger 8’ disc mower, IH 990 mower, Kuhn rotary rake, enrossi. Rake/Tedder
Yahoo
Edszut@gmail.com
Edsfarms's Achievements
Ford 6.0 guys have I lost my everloving mind?? Input welcomed!
Edsfarms replied to B.B.'s topic in General Chat
X2 👍 -
The valve is a coil, When you apply 12 V the coil and a ground it creates magnet field actuating a valve in the body that when you remove power the magnetic field is gone and a spring closes the valve. see if a metal blade sticks to the top of the coil when it has 12V and ground applied. FYI you can bypass your switch and wiring with a set of jumper cables directly to the battery. if the valve is staying open without 12V o I’m guessing sticking spool valve or weak spring hope this helps!
🙏 for All involved
@CIHTECH I’m sure yes, just to clarify, too tight. meaning you tapped them in thru shift collar into shift piston slot. But did not jack them up with set screw
What parts did you actually replace? something is not allowing the shift piston to mo
Here is my 710 with combination gauge/tail wheel
Here is a link to my PTO pin replacement. https://www.redpowermagazine.com/forums/topic/136963-another-5120-pto-needs-shift-pins/
Check this thread from previous https://www.redpowermagazine.com/forums/topic/135777-case-ih-5220-pto-problem/
I am thinking the pins are still in the shift collar and hollow tube. They are threaded in the center, you can install a set screw tighten and it will back them out, or take a large drift and knock the hollow shaft thru but you will shear off the pins ( pins that are laying on the bench in pic) and they will need to be replaced with new ones. if you are that far into this project I would look for any play on the reversible 540/1000 shaft and drive tube. Consider replacing everything to prevent another failure/ leak.
Poettinger in Business since 150 years manufacturing farm equipment
Edsfarms replied to U-C's topic in General Chat
Now I know how to pronounce the name of my Pottinger 265H disc mower. 🙂. Thanks for sharing! -
The chart is for forward and reverse. However checked my speed with phone gps today. 4th gear no t/a was 21mph at 2200 rpm
MPH from my 885 dash chart
Did you get a chance to troubleshoot??
Hi, the photos should help get you to so what understand what is happening with your 5130 trans, and get you some initial troubleshooting. Follow the flow chart and report back findings. The “check trans “ light is above lightb switch and the “ clutch disengage” is above ignition key
