Ok Thanks guys ,I have the sheetmetal off ,the one on mine is Eaton, I have a used sunshield to put on it ,both are for 4 wd mine isn't 2 speed ,somewhere I got the idea that 2 speed was only available on 1480 .Now my next problem, the motor to change rpm on my cylinder stopped working so I took it out and checked it and motor works good both direction ,so I check rocker switch in cab ,with key on engine off ,power to switch but none coming out either direction, tried it with cylinder engage switch off and on but nothing running, am I proceeding correctly in diagnosis or do things need to be running, I hope I didn't make this confusing. Thanks again for the help!
