waterflea
    6
About waterflea
  1. The mice thought my dash on my 1976 Hough payloader would be a good place to build their home. Unfortunately they chewed a lot of wiring when they were redecorating. Any body have a wiring diagram for said tractor or something similar or know anything about wiring a Morse B62473 four wire neutral safety switch into the starting circuit? Any help would be greatly appreciated.
  2. Oh I was so hopeful too. Rotated pump 360 and nothing, not even smoke out the exhaust which I was getting before.
  3. Ok, I'll give it a try.
  4. Maybe it's possible but @ TDC both valves on #1 cylinder are closed (rockers are loose) and the Injector pump pointer lines up mark. What am I getting wrong?
  5. I'm trying to get a 1976 Hough H65C payloader with an International DT414 engine running after many years of not. I have replaced the sleeves and pistons. Complete valve job. New turbo. Injector pump rebuilt. Injectors tested. ( test a little high but all consistent). Will not start without starting fluid. Will eventually stay running but not well. Have timed @ 15BTDC as per specs. Have also tried other timing settings. Does not want to start on it's own, runs rough, smokes a lot. Would appreciate any help.
