Brad Bauer
Brad Bauer's Achievements
  1. Thanks Junk and cattle I am trying a couple of historical societys as well on the model. When I look up a model 37 disc for parts the adjustment for angle is different. Mine is a sawtooth bar that when lifted and pulled will increase the cut, and when you back up it will straighten out Brad
  2. So there is no bearing per say, like in a a main or rod bearing where you have the bearings retained by the shell. Any idea on what model disc it is or where I can find out
  3. For now that is the thought. But long term I would like to fix it back up and even see about painting.
  4. I have kind of looked at different sites, I guess I am not quite sure what I have to know what to look for. Is it a bearing similar to a main or rod bearing or something totally different. I have not had it apart yet.
  5. I have a disc I would like to know the model of and get bearings for it (i suspect they are bad) it is 7 feet across when straight and discs are about 20 inches in diameter. The spacer between the discs has PB 3058 stamped on it, and the bottom of the bearings has P 3120 stamped on it. I grease it before using it and until a little grease comes out the bearing. I use a full tube for all 4 bearings. This is why I suspect that the bearings are bad.
  6. Where can I get manuals for this plow? I have had the plow out and it seems to work ok. It is not set up right but close. Thanks and Happy Fathers Dad to all the Dads out there
  7. I would like to return it to original and paint it, if it is worth it. it does/did work. I got into a stump or roots and it took effort but went through them. Later on the middle coulter stem broke. Had it welded up again. Just had it welded up and waiting to try it. It looks like the coulter set on a old moline plow I have there also.
  8. I just got a new (to me) 3 bottom plow made by Intetnational. I am hoping someone can tell me what model the plow is and where I can get some parts. Numbers stamped on the middle beam are P012572. On the furrow side P017184. And the land side is P013813. The middle coulter was replaced with a different one from another plow, and the hitch was converted to a straight hitch so there is no release. I would appreciate any help and information Brad
  9. I recently purchased a pull style 3 bottom plow. I do not know the model of the plow and some fast repairs have been done. I would like to get it back to original if I can. The 3 beams have numbers stamped on them. The furrow or right beam is P017184. The middle beam number P012572. And the land side or left beam number is P013813. I know the middle coulter assy was changed and does not match the other two. The stem is broke, so I will need the complete assy. Also the hitch has been modified to a solid hitch and that will need to be replaced with a different one. I appreciate any help I can get. Brad
