The a/c quit cooling while running on auto. I thought I'd try manual by moving the switch to the center position (I believe that puts it in manual), then it really lost cooling, so it must have been working somewhat before. So I flipped it back to auto and turned the fan speed to high. Then it seemed to cool better but I would not call it good. Then at the end of the day I noticed the fan itself would not shut off when I moved the switch back to the center. The fan always runs with key on, not the cab pressurizer fan, the actual fan. I don't know what's going on here. Not codes on the little digital display, it just shows temp setting and it does move when the temp knob it turned. I haven't had gauges on it yet, does this system cycle the compressor to regulate temperature? Or does it move a diverter door? The coolant it shut off, so I know it's not heating heater core. I don't know if I have 2 different problems with the fan and cooling problem or if they could be related. I haven't studied the system much at all yet. Any ideas?
