jsmithsfarm
    3
About jsmithsfarm
  1. It will move but it sounds like it’s coming apart it grinds so bad. It started out just doing it every so often, but when I tore it apart it was doing it every time.
  2. It has a ta. It only does it when you put it in gear and let out on the clutch, it doesn’t matter what gear. If it’s in neutral it won’t do it
  3. I have a 806 that would grind when you let out on the clutch no matter what gear it is in. I’ve took transmission cover off and checked gears, broke it into and checked clutch, checked clutch brake. I can’t find anything wrong. I need some help. Thanks
