Keith 1066
Content Count
35 -
0 NeutralAbout Keith 1066
Rank
302 profile views
It has a rod hangin out the side of the block.
I found a motor in a 1981 truck with a rotary pump on it. What would have to be changed?
My uncle blew a motor in his combine. I was just making sure before he went out and bought a motor, that a 466 out of a truck would directly bolt in.
I have a Bosch RSV-375 off a case tractor. I was wanting to put on my 1066. Would does it take to swap the pumps. I know I will need new lines, will I need a different gear for the pump. Would this a pump put out more than the rotary now. Thanks.
I have the plate out of my pump, and I have 19 degrees of timing. Would those tips help any? Also, could I give it some timing.
I am a farmstock puller. My local diesel shop told me about some 5x.020 mack injector tips. I was wondering if anyone has ever used them.
I had the lines swapped on the mcv valve which caused the brakes to stick
I 10 mm pump would push a gt 42
Would a stock pump push a s300
I have a stock model 100 pump maxed out. I have the plate taken out of the pump. I pull the tractor in farmstock classes. I was wondering if I should go with a 3lm or a S300.
This is a ta delete tractor
Could that cause my mcv valve to have issues.
Keith 1066 started following MCV valve question
What is this piece on my mcv valve
it is almost impossible to steer with the tractor at idle
We have disced some ground with the tractor and the brakes are still sticking the tractor sat outside for a while. We bought the tractor and put a motor in it. The tractor steers fine, clutch feels good. I have no brakes and the brakes are locking up. I would appreciate some help
