Our 275 magnum has been having an issue with not wanting to move in the c1 gears, 1,2,7,8,13,14. Sometimes it works great, other it won't move or will act like it's struggling to go in gear, most of the time you can move the shuttle to park and back a few times and make it work again. All pressures check out by case tech and it will pull through the brakes when it works. I have tried to calibrate it a few times and it gets to c1 and maxes out milivolts right away then says cal high. We changed c1 solenoid and it didnt help. We finally got it to throw a trans code 81 a few times when it decides to not work. We have changed the wheel speed sensor. Next is the alternator, but I have a hard time believing it would only mess up in a certain clutch pack. Neither us or the case tech can figure it out. Any help would be great.
