Content Count
11 -
2 NeutralAbout bapsdad
Rank
Gender
Location
VERMONT
Interests
TAKE IT APART AND FIX IT all most anything working on my 270A backhoe I just bought helping my friends
94 profile views
bapsdad started following newbe with a 270A, Bad day for Team Green and ?? for the electricians here........
Iook at the picture again the outer rim is bent on the inside and the axel housings is off as well not just the axel My guess is someone was going to fast and went off the road
Just to let you know everyone here has been fooled by the power company it is not electricity they sell but smoke all he needs is new smoke retainers for his motors case in point look at wire size . Starter motors take a lot of smoke to turn a motor over that's why large wires more smoke. Light bulb small wire less smoke And no matter what you do if you let the smoke out it doesn't work be it the part or the wire So if you want get the model number of the motor and look up on line for a smoke retainer for it or if you have a local fire department they may have a spare one
Thanks for the info I bought a service manual from eBay but it doesn't cover everything I'm having a problem with it jumping out of high or low range at times The bushings are worn but at times it will go right past the range your trying to shift to it looks like the King mite have had his hands inside the cover where the high low are but will order bushings and see if that works
I still have a list of things to do before paint still have a few pistons leaking I have the kits just don't have the time. And it needs to be rewired front to back Needs a few new pins has some play in the hoe And get a new cable for the emergency brake Other than that I think it Will be ready for paint But with cold and snow on the way it will be spring before I do much more work on it Can't get it in my garage so I'll cover it up pull the battery and hope for a early spring I'm not computer smart to do videos I do like youtube to help with repairs or rea
Holding strong after boulder We also cut the 12 inches of 1/2 inch plate off the top of the front bucket and used some of that to fix the outrigger
Will check for crack next nice day I have I forget to show a picture of the great job the welder did on the outrigger Nice looking backhoe I think you get what you pay for I paid $500 for mine and put about $3000 in parts not counting my labor or all the welding it needed that I swapped a guy he fixed my outrigger and I did head gasket on his old Volvo But I must say it has money well spent I've done 2 jobs that put it to the test pulled 3 big tree stumps out of my son back yard and finish it off so they could get married there in 7 weeks And a friend of mine called said his water
Nice looking backhoe I think you get what you pay for I paid $500 for mine and put about $3000 in parts not counting my labor or all the welding it needed that I swapped a guy he fixed my outrigger and I did head gasket on his old Volvo But I must say it has money well spent I've done 2 jobs that put it to the test pulled 3 big tree stumps out of my son back yard and finish it off so they could get married there in 7 weeks And a friend of mine called said his water was coming up outside of the house not in the house so I had to dig for a new line and it was all clay and big rocks an
worked on the water pump mounting plate and found more of his handy work he had a small bent square stock welded to a piece of the broken exhaust manifold and tacked to the stud at one time it didn't hold , then look what he did for exhaust I think I'll start looking for a good used one now and get the right muffler for it and he cut the hole in the hood to fit not much fixing the hood cant wait for the nights to stay above freezing so I can start cleaning this thing
I'm a need to know guy I've bought the parts and owners manuals aftermarket back in November and the service manual original print from eBay just got it last week this is my 3rd IH backhoe my first was a 2400 I paid $1200 put about $3000 into rebuilding the motor including cam bearings because of low oil pressers. rings ,bearings valve job 1 rear tire rebuilt main boom and bucket cylinders used it for about a month and sold for $9000 to pay divorce lawyer my 2nd was a 1963 460 6 cyl open cab paid $2000 for that one only had to fix the brakes and 1 lift cylinder on the front bucket t
called the dealer today they reordered don't know where the other went ? mine is a torque converter transmission and what you see is how I brought it home it has been to cold to turn the water back on to the garage and use the presser washer that is still in the basement I don't think it has a lot of hours on it I think the last owner was the king of cob and abuse or didn't know how to weld or his welder was not big enough I think he was using the outrigger as a park brake and for got to pull it up all the way and ran into something as you can see it was lettered and pin striped a
Hello I bought this 270A back in November but just getting to really looking at and working on now .it took a starter , battery and injector pump to get it out of the woods after setting with the normal filter changes and fluids replaced all but the hydraulic because I had to order filters and I couldn't put any more stuff in my wrangler it was about a mile and a half in the woods where it set for 10 years. found it on Craigslist not running make offer was told it needed a injector pump it was 64 miles 1 way and it took 4 trips to get it going and get it home it runs great front buc
