Kenny m
    20
About Kenny m
  1. Ok will let you know what it does when I get it that's for all the help.
  2. Did you get my message I sent you one back just checking
  3. Not sure I've never herd of them
  4. I'm in southwest va no good dealers around really I have checked the Hertz to the rpms on alternator and it now has new on and off switch, on and off valve and pto speed sensor and when the computer was getting power out of the bottom side and I had it on and got out of the seat the alarm would go off so I figured it was good sense it was seeing it
  5. Ok just put new pto switch in still nothing it now has new switch, pto speed sensor and pto on and off valve alternator tested good with the rpm gauge checking the Hertz on the alternator still no juice coming out of computer but have it going in and my pto light just all the sudden quit working and it has been working fine not sure what happened there but wondering if anybody had anymore suggestions before changing computer?
  6. Ok just put new pto switch in still nothing it now has new switch, pto speed sensor and pto on and off valve alternator tested good with the rpm gauge checking the Hertz on the alternator still no juice coming out of computer but have it going in and my pto light just all the sudden quit working and it has been working fine not sure what happened there but wondering if anybody had anymore suggestions before changing computer?
  7. Thank you dealer could not find it
  8. Do you have the part number for the one you got
  9. Anybody know were I can get the lever style pto switch. went to dealer all they can get is the push pull they ordered me one but I would rather put original one on if I can still have no pto but the switch has started testing bad now
  10. Done alternator test everything checked good been working on it for a couple days switch went bad on me it dont work no more I guess we have turned it on and off to much. And the on and off cartridge valve was stuck and wouldnt move witch may or may not have been the trouble the whole time got the parts ordered will see what happens. I still was not getting any power out of computer going to pto when the switch was working tho so still not sure about that.
  11. I feel like it is simple it's just finding it apparently it didn't work when it came back from dealership the last time they worked on it from what I have gathered
  12. Thank you gearclash I will check that tonight and see what I find
  13. Ok thank you I will say I have been told this tractor has had a new transmission and brakes done on it and the cab has been off and it could be wiring but I've traced wires and cant find nothing I'm not getting power out of the other side of computer now. I was at first now I'm not and the pto light just flashes constantly when engaged
  14. I am really starting to think it might be the computer anybody know how to check it
