Youngred2000
Youngred2000 last won the day on July 10 2019
Youngred2000 had the most liked content!
Youngred2000's Achievements
  1. I took the battery with me and had it on the charging rack in the shop or bring them in the house with me in winter. When leaving any gas machine in the field I take the rotor out of the distributor so no one can mess with it, knock on wood no one's taken a tractor but I had a old 990 haybine stolen
  2. He said AC people are special so I guess in his hart of harts I am special then.
  3. I like Alice in chains nutshell alot I know GNR is pretty over played and quite over rated but GNR civil war is pretty good. I have yet to find any def Leppard I don't like same for the older ZZ top stuff. My all time least favorites are anything pearl jam or worse yet Nickelback.
  4. I am wondering if anyone has mowed it with one of those old new idea cutditioners with the big flails. I used one once in old growth meadow hay and it broke it up into perfect 4-6 inch blades and made decent sheep feed.
  5. I usually aim for 1 cut and hopefully have another 1-2 feet of regrowth for plow down. Two years ago it was too wet and it got away from me so I don't get to hay it and was about 8 feet tall when I plowed it under.
  6. Central MN. 4-5 days usually I have the rolls on my mower pretty tight and drive slower to make sure it get time to crimp well
  7. I do't have any experience grazing it how ever I do grow 20-40 acers a year for haying. I wonder if it could be high in nitrates being that short. My understanding is the plant starts off toxic then grows out of it and the toxins dilute as there is more plant tissue. I believe that the leaves are highest in toxins and that is why they recommend not grazing the regrowth until it's a few feet tall. Is it pure Sudan grass or a sorghum Sudan? As they are too very different animals when it comes to toxicity sorghum hybrids usually being more risky then pure Sudan grasses like Piper
  8. The local subway now has a $15 dollar foot long. Just the sandwich nothing else $15 so much for the$5 foot long.
  9. Saw a M muffler on a civic before
  10. I bought a 560 awhile back at an auction for a couple hundred bucks with the radiator and some of the tin missing the motor was locked up and I have sense gotten it loose. The tractor will not roll on the right side even with the breaks completely removed from the tractor on that side. The shifter lever shifts into all gears smoothly the tractor also has a hole hacked in the hood with a big pre cleaner sticking through the hood and a dry air filter held onto the fuel tank frame with self tapping screws. There is also a pipe coming off the oil drain plug at the bottom of the pan maybe a turbo return line? I think someone had a turbo on it at one time and was using it for heavy tillage until something went in the rear end and then the motor got suck from rain water and maybe robbed the radiator for another tractor? Would this be considered the later head with bigger valves?
