Rookie17
    13
8 Neutral
About Rookie17
286 profile views
  1. Either way it’s drilled and mounted now. I have a set of flat fenders laying behind it. Just got ran a die down the U bolts so I can get them mounted on. Then hopefully one day painted. Thanks for the help!
  2. So we pulled it off an 806 and it appeared drilled to me... but you never know if something has be cobbled together or what’s going on. He had a stack of washers on every bolt to space it out.
  3. Thanks! Is just a 15/16 spacer on the rear or front bracket as well?
  4. So I’m trying to mount a 2350 loader to a 806. The rear bracket from the measurements I took appears like you have to drill 4 holes through the tractor frame on both sides to get it to work? Then I have read other things saying it should bolt right on? Does anyone have any pictures of the rear mount of any input on that? thanks
  5. So I’m trying to mount a 2350 loader to a 806. The rear bracket from the measurements I took appears like you have to drill 4 holes through the tractor frame on both sides to get it to work? Then I have read other things saying it should bolt right on? Does anyone have any pictures of the rear mount of any input on that? thanks
  6. This is exactly what I was thinking was that case thanks for that picture.
  7. The reason I ask is that my panels are bent out to fit this radiator shroud. Someone pounded on them with a hammer to bend the out around the shroud.
  8. Did the 806 have a fan shroud? I think someone has added this to my tractor?
  9. So when my grandpa bought this it had this set up on it... it looks some I’ve took combine parts and made some sort of air filter. He never cared he was pretty practical. They cut a huge hole in the hood and ran the pipe through it to that big air cleaner. I have since got a hood and the right air cleaner assembly which came off one with this exact set up, minus the combine parts. I know I have more pictures I just can’t find them in my 5000 pictures. Lol
  10. Thanks you that will help a lot. 👍🏼👍🏼
  11. So, I have a lot to learn my turbo says airesearch t104... i saw another one up north with this turbo? I assumed they were off a 1206? My boots are rotten on the turbo inlet and it had the wrong air cleaner on it. So I got the right stuff... any idea on that ? Thanks!
  12. I just got this from my Grandpa, needs a fair amount of work to keep her in the family. The injection pump is and RD and is leaking at the throttle shaft. In one picture you can see I took the primary/transfer pump off. The primer knob/gravity feed knob broke off. I had it repaired. I know the throttle shaft o rings can be repaired on the tractor. I have seen other posts, but not a procedure or a parts diagram. I called Precision Diesel in Red Oak Iowa and Rex recommend I at least find a parts diagram. I saw IHbrad had some procedure but I couldn’t message him for some reason. Any help would b
  13. So first off I have never posted anything to a forum ever. So I have no idea if I’m in the right area. I pulled this cab off an old 806 I’m putting a clutch in the owner doesn’t want it. I was going to scrap the cab and I pulled the glass out. The glass that is broken is the right side pane, the rear, and the upper door glass ps. If there’s no interest I’ll take it to the scrap yard by Friday. Email me phil2875g@gmail.com. I’m thinking $200. obo... thanks
