Mike Stearns
Everything posted by Mike Stearns
  1. Does anyone know what the cca for a 50’s r200 with a rd450? Mike
  2. You keep that up, your going to have to add a roll cage. Mike
  3. I know what you mean about dead lines. Mine is October and I still have lots to do. Mike
  4. That’s going to be a bit loud! I’m going to buy stock in ear plugs. Mike
  5. That’s why they came with a air shut off valve
  6. The worst part is finding one and the price. I use to pick up one anytime we needed one, but now they are a week out. The price has been going up 8-10% every couple of months
  7. The problem you are having is common in my neck of the woods. It’s caused by an iron bacteria that’s in the water. The bacteria thrives in the water heater. The cold isn’t affected. The other problem is there’s not enough hot water being used to keep it flushed out. The only way to get rid of it is to bleach the system. You will need to drain a quart of water out of the heater and add quart bleach. You can either remove the anode rod or the cold water line. Let stand for 2 hours. At that time, start at the closest hot tap until you get the bleach smell and shut off and go to the next one and so on. Wait another 2 hours and start flushing at the first tap until bleach smell is gone and so on. This kills the bacteria in the heater as well as the piping. If you change the water heater, most heaters don’t last that long, you’ll still need to bleach the system. Just add bleach to heater and fill. If the house is on a well, You may also want to contact a well company and have the well treated as well. I’ve even seen this problem on city water. Mike
  8. From a quick search, it appears that the 153 is a splash lube for the wrist pins and rings. Mike
  9. I would check the oil system. Galling would mean lack of oiling. Depending on make and year would depend how they are receiving oil. Just my 2 cents worth. Mike
  10. Sounds like either wrong pistons or rods. Was it a rebuilt engine when you got it?
  11. That’s how or why I got mine. The department was all for it, but when they got to look at it in person, they saw all the work it was going to need. The older personal was willing to do all the work needed. I was asked to move it out of the department for our annual fish fry. So I moved it to my garage. This also made it easier for me to work on it since my tools are closer. It has never left the property. They finally decided they where not going to spend any money on it. They then finally approved giving it to me. I have since retired from the department. I do support them when needed. I think it’s funny to me that they ( younger members mostly ) don’t care about it or their history. Most can’t drive anything that isn’t modern enough. They house two main line pumpers. A 1978 and a 1992. They are pump tested every year and the 78 has always out pumped the 92. They have 1000 gpm and 1250 gpm pumps respectively. They very seldom use the 78 unless the 92 has to issues on a seen. They just want to have the newest stuff with all the bells and whistles when the older stuff works and performs better. Mike
  12. So what are the yields? I haven’t heard any
  13. Virginia creeper is what I call it
  14. The wife and went to a flea market today and saw this as a display. Just you all would like it. Mike
  15. IMO, go paper if that is what was in it when new. If they wanted it to have an oiled filter, then it would have came that way when new. Mike
  16. We had a 20’ pontoon. Great fishing boat. The wife started calling it “ The Professional Worm Drowners “. So I painted it on the front gate. When asked, I would just say “ the wife’s idea “. Mike
  17. You will need to know the serial number of the block when you order gaskets from Olson’s. You may also need a picture of the block with the head. I got a kit mid spring and cost about $600. It was very well labeled and great quality. Mike
  18. We had a tile contractor hire us to core holes in floor tile, 24x24, for floor drains and clean outs. We used a big core machine with a 6” bit. Took me all day to do them and only broke 1. Customer was quite pleased.
  19. I’m a plumber by trade and I’ve drilled more holes in tile than I care to. The mini core bit works best with lots of water with a drill speed of 2000 rpms. You can pick up the bits at the big box stores. Mike
