cipltd
    6
About cipltd
  1. cipltd
    1066 problems
    Yup full of oil. like i mentioned a bit ago. the Case mechanic said my ta was gone. so i was wondering if that will affect the steering and the propulsion. on another note, are you guys have issues with Vomitoxin ?
  2. cipltd
    1066 problems
    Yup full of oil. like i mentioned a bit ago. the Case mechanic said my ta was gone. so i was wondering if that will affect the steering and the population. on another note, are you guys have issues with Vomitoxin ?
  3. cipltd
    1066 problems
    is the steering, motion and TA all work on the same system together? .
  4. cipltd
    1066 problems
    That's the thing Matt, after using the pto the tractor won't move at all. I put it in gear (any gear) after and it just does a little jump then sits there.
  5. cipltd
    1066 problems
    Thanks Sparky and Matt. I changed the Hy filter 2 years ago when i did the clutch and not many hrs on since then. I will try the plug when it stops raining.Cant get it in the shop because of steering.For Matts reply, I had a Case mechanic here last year and he told me the TA was out.all this tractor does is running grain vac and putting in surface drains. What is the MCV?
  6. cipltd
    1066 problems
    Good Morning all, I have 1066 with no steering and when i put it in gear it does a quick little jump but doesn't go any where. Works not bad until I run my Walinga grain vac then won't steer or move. Any suggestion?
