MBman
MBman's Achievements
Newbie (1/3)
1
  1. I have an MXM 155 with about 7000 hours for the last thousand or more hours we have had some serious steering issues. It is mainly obvious on the road but it came to a head on Saturday. I was driving down the highway and slowly veering into oncoming traffic, I knew it probably wouldn't steer so I started counting steering wheel revolutions, it took me 6 full revolutions before I started getting a response on the front wheels. This is mainly an issue on the road in the field there is enough steering going on that it seems like it keeps pressure better. It seems as if when you are not steering one side or the other loses pressure and then you need to make an aggressive jerk on the the steering wheel to get it to pressure up again and let you steer. It is just a whale to try to drive on the road, and I am afraid that someone could have a real bad accident since this is just happening all the time. On Saturday I was baling and I even had issues staying on the windrow because I was just not getting steering response. After I got home I checked the temperature on the transmission and the pump was at 200 degrees, and most of the transmission housing was 150-175 degrees. This does not seem normal to me. We have had the dealer pressure test the steering and they seem to think it is fine as far as specs go, we have changed the steering motor in the steering column. Any Ideas would be much appreciated. My service lady at the dealer thinks maybe the pump is going and causing high temperature. Would high temperature be enough to make it stop steering normally? I know that the transmission has run HOT for quite awhile.
  2. Hey thanks that puts me to ease a bit. I do change mine. Last time was 550 hours ago.
  3. Hello I have a 2014 4530 Titan floater with the Iveco engine in it. The other day I noticed dirt had accumulated on the outlet tube on my air to air cooler downstream of my turbo. So yesterday I popped the hoses off going to and coming from the turbo. The outlet side of the turbo is just black and grimy and sticky but when I smear my hand around in the tube it doesn't come out oily the grime is just stuck on the sides. I even pushed a flexible rubber strip down to the bottom and it comes out clean. The inlet side of the turbo, coming from the filter had a bit of oil in it as well as the elbow, I've talked to my local mechanics and one of them is coming out tomorrow. But thought I'd ask here. They wonder if I'm pulling oil from my case breather. If my seals went does the oil blast out in such pressure as to blast through the intake turbine and up against airflow coming in? And the fact that there is just a tiny bit of oily oil and the rest seems old makes me wonder if I need to replace or not? I don't remember needing to add any oil at all last fall when we were finishing up. Or is the air coming through there hot enough to bake the oil onto the sidewalls? The tube up to the air to air cooler isn't filthy just right inside the turbo.
  4. Hello SDman I just posted a new topic regarding a 7130 FNR spool would you mind taking a look and giving me your opinion on the matter.
    Thanks a bunch
