656IH
    65
About 656IH
  1. Hi Bob, I'm in Washington mo.(50 miles west of saint louis).
  2. Very helpful, thanks guys.
  3. Looking into buying a 544 Famall,what would be a good loader to put on it? Thanks guys.
  4. Thanks guys, i will check that as well. The ground cable is the old flat braided kind and it looks ragged. One thing I notice too is that if I leave the key on while testing ,my ballast resistor will smoke. Only takes 5 minutes approximately.
  5. Using a test lite I went from negative post on battery to the frame .
  6. Thanks, the diagram is perfect. 🤓
  7. How does the wiring need to function to engage the starter? At this time I have the main cable from pos side of battery to the large post on solenoid, a power lead from starter button to left small terminal on solenoid, and a lead from the right small terminal on solenoid to the key. Cannot get starter to engage. Had a rat build two nests behind the dash and made lunch of my wiring. So I'm rewiring it. Also, I have a positive charge coming from the frame. What would cause this? Thanks for any and all help.
  8. Does the 2 point have a depth control feature? Is there a draft or traction control? Thanks guys.
  9. 656IH
    300 farmall 2pt.
    Sure would, thank you.
  10. Sorry guys, got clutzy with my fingers. Would there be any advantage to putting on a 2pt then using 3pt adapters vs just putting on an after market 3 pt? I have a 300 farmall that currently has a standard draw bar. Thanks.
  11. 656IH
    300 farmall 2
    Does anyone have a schematic of the parts that the original wide fronts had for the 450 farmall. Mine is the adjustable type. Mainly need to see what parts go with a complete spindal set up. Thanks guys.
  12. Thanks for the info. Found it.
  13. Does anyone have a schematic of the parts that the original wide fronts had for the 450 farmall. Mine is the adjustable type. Mainly need to see what parts go with a complete spindal set up. Thanks guys.
  14. Still at it trying to find 6 bolt hubs for the 450 farmall wide front. My 450 spindal has part number 358960R1 cast on it. Putting it on a 1967 Farmall 656. Want to use the original rims on the front. Does anyone know of a source for the hubs? Axial al, do you know the hub part number from all states ag parts for the hub you got for the 400 wide front that you put under your 560? What by chance was your spindal number? Thanks al and to all. Thanks guys.
