nomorejohndeere
Everything posted by nomorejohndeere
  1. seems like some of the structure of the guard should bend and warp and dang near fold over before a weld would break all the way like that. but hard to tell from pics sucks it took out a tire as that stops miles until replaced
  2. If holes in the road are called pot holes what do you call that?
  3. Looks like tricky dicky trying for a link click.......
  4. All are very very similar The internals are/almost interchangeable Most of the wands are plastic and not very good. A good hardware store/farm supply will have a wall of metal wands and nozzles to replace when the time comes They pump fine just don't let them sit with chemical and dry out. The plastic strainers eventually break and the straps give out. The Stihl is commercial and made different than the rest. It is an azz kicker, everything about it is made to last including a nice metal tip. Pump is external and the linkage for the handle is all metal. The filler cap is hard to get ahold of when tightened up because of the large rubber sealing washer and will make you wonder what they were thinking. Nice carry handle rather than a loop of strap that gets wet and stays wet and breaks like most others. Kind of tall and skinny? make sure it's sturdy before filling as to not knock it over. All parts are available. Mine grew wings one day as I ate lunch..... The rechargeable ones are nice if you want to use while mowing or on your scooter, tractor, etc. as you can steer with one hand and point and spray with the other.....I prefer the type that uses a replaceable battery like a cordless tool. The ones that have their own batteries are down while charging and are heavy...
  5. just run one side rear tire about flat.....
  6. when you say twist do you want to tilt? as in one side of blade up or down compared to the other? if so replace one of your three point arms on tractor with a hydraulic cylinder.....
  7. why would you want to kill a cat?
  8. I had a triple axle with those clamp wheels that went the nomore way I've needed a trailer to replace it since as it was very handy but always fighting tires Better have three spares to make a 100 mile round trip.....
  9. You will have to add the piston oil lines larger cfm fan and an air cleaner for more flow don't forget the chrome stack exhaust....
  10. I heard a noise in the front yard and ran out to see the biggest rattle snake ever. Uncommon in these parts as we usually just have copperheads. Anyways I did the usual and grabbed it as it struck and bit him instead. Turns out it was the skinny neighbor kid dressed up for Halloween.
  11. https://www.facebook.com/marketplace/item/304493702361930/?ref=browse_tab&referral_code=marketplace_general&referral_story_type=general&tracking={"qid"%3A"-3180271614441217596"%2C"mf_story_key"%3A"310124701273709264"%2C"commerce_rank_obj"%3A"{\"target_id\"%3A310124701273709264%2C\"target_type\"%3A6%2C\"primary_position\"%3A4%2C\"ranking_signature\"%3A0%2C\"commerce_channel\"%3A1000%2C\"value\"%3A0%2C\"upsell_type\"%3A107%2C\"candidate_retrieval_source_map\"%3A{\"7583852744962092\"%3A805%2C\"5966066870163426\"%3A630}%2C\"grouping_info\"%3Anull}"%2C"lightning_feed_qid"%3A"-3180272370287196119"%2C"lightning_feed_ranking_signature"%3A"3908233393590516768"%2C"ftmd_400706"%3A"111112l"}
  12. have somebody with a 3D printer copy it
  13. I've got 55 as well...
