Hi all.
I have a case international 885xl 1990 model. The engine has recently been rebuilt and for whatever reason it struggles to start but will turn over after about half a miniute or so then it losses power straight away and will not respond to the throttle or reach the rated rpm. When turning over it produces a lot of white smoke which does clear. I have drained the fuel tank and cleaned the banjo bolts, replaced all the fuel pipe all the way to the primer pump. Replaced the fuel filters, bleed the system, the injector pump has been reconditioned and all the injectors have had new nozzles. I removed the air filters and will replace them as soon as. However I tried starting it without the air filters and the problem still persists. The only other symptom is at idle it produces a light grey/white smoke and smells of unburnt fuel. The oil is as should be and not milky in anyway and the coolant level doesn't drop at all.
All help and advice greatly appreciated
Regards
Luke
