MarkG
Everything posted by MarkG
Put the top link in the top hole on the 3 point bracket on the tractor. Will only help a little but every little bit helps. If you’re using the bottom hole and you travel with the lift all the way up and the top link has a sharp angle down. That’s your problem!!
Please post a picture of the pump.
The rotary injection pumps are notorious for having the plungers stick after sitting for a period of time. When the cam in the pump comes around it pushes the plungers out and this pumps the fuel to the injectors. When the cam passes it is up to the supply pressure to force the plungers back down and fill the cavity with fuel. The plungers are machined to close tolerances and it only takes a little bit to gum them up and the supply pressure to move them is very low. EDIT: After finding the diagram I realized I described the process wrong. There is not a cam but a cam ring that forces the plungers in to do the pumping. Same principle though. I should leave the explanation to the experts like @Injpumped.
Delphi. Thats the pump I’ve got. Besides being a pain to time it has some form of torque limiting. When I hit a hard spot mowing the engine falls to its knees. Anybody know if you can replace this pump with something better?
Are you saying in 1973 the 966 Hydro and Hydro 100 were available but not the 1066 Hydro? I’m interested because I’ve got a 1973 966 Hydro.
I’ve got a McCormick cx75 with the Perkins engine. You need to time the engine before you take the pump off. The pump shop will rebuild the pump and lock it. You reinstall the pump then take the lock off the pump. I took my pump off without timing the engine and it took me forever to get it timed right. Good luck.
Need a Water Pump For a Generator With a Deere Engine
MarkG replied to FarmerFixEmUp's topic in General Chat
I thought they were all plastic impellers now a days. -
Some times the jd engine serial number will not show up for jd dealers if the engine powers another manufacturers equipment. They want you to go back to Koehler to get the parts. -
I love welding. I’ve bought many welders. But I’m a terrible welder!! One thing I’ve noticed is I have poor fore arm strength and poor stick control. With a stick welder, if the rod goes way out of the puddle from time to time it still makes an ok weld. On the mig when the gun goes out of the puddle that’s when the arc extinguishes and you get the push back and horrible bead. I have to put gloves on and use two hands to keep the wire in the puddle at all times.
TIG welder for aluminum - best, worst, or just RUN!
MarkG replied to Mountain Heritage's topic in General Chat
You can turn any stick welder into a tig welder. If you have a stick welder already a high frequency box might be an option. I don’t know if the high frequency box requires dc or ac welder input. -
Another timing method is to remove the valve cover so you can see the rocker arms. When 6 is rocking your timed on number 1.
- 12 replies
- 1
- international
- hydro
(and 7 more)
Tagged with:
Sorry for hijacking the thread but I love the videos of Indians working. Notice the dirt floor that never needs to be swept. The steel toe sandals, and the auto darkening safety glasses. 🤣🤣🤣. I do not want a tractor that these guys make!!!
When I read the title I thought it was a post about old age. I was ready to tell some of my stories. 🤣
I saw it there. It’s a beautiful tractor. I wanted to open the door and look inside but I didn’t dare touch it without permission. Was the other 1086 yours also? While I was there another person was admiring the 1086 with the factory cab and reminiscing. He said he remembered going to the same show years ago and seeing the new 1086 at the international tent.
We’re the pto gears a weak point on the large frame tractors?
I saw this at the Ag Expo today. Does anyone know if it belongs to the forum member on here? I think I remember him doing a build thread on a 1086 with a year a round cab. Good looking tractor.
I think a Ford 5000 was rated at 70 pto hp.
Yep. I went to a Cummins training class and they said its inside the injectors. Engine manufacturers have drastically increased the injection pressures to make the mist finer for better combustion to comply with emissions. This extreme pressure and heat causes a chemical reaction resulting in asphaltines. The small amount of fuel that goes back into the return line on the injectors carries the asphaltines back to the tank.
