MarkG
Gender
Location
Alapaha, Ga.
2,485 profile views
MarkG's Achievements
1.1k
Welcome to the forum. Always enjoy hearing from people who love country living. Everyone here loves pictures so if you’ve got any crops or animals please post some pictures.
The double drops can be very handy hauling tall loads but they will bottom out going over high humps like some rail road crossings. The double drop has smaller tires and might have tires that are rated for much less weight than a standard tire. Definitely get a 102 wide no matter what you get unless you plan to go to a state where they are not allowed.
Would adding an aftermarket filter housing extender help in cold weather? It’s my understanding the housing extender allows you to stack two stock hydraulic filters.
I thought the 66 series were being made by 1972.
Just thought it was funny.
If I’m not mistaken those two lines go to the control valve. People have replaced them with hoses but I was told this is a bad practice because of the expansion factor of hoses. The guys at Herrs Hydro in Washington Kansas make the lines to replace them.
Roundup from $4000 last year to $14,000 a 1000 litre shuttle this year
MarkG replied to 5288IH's topic in General Chat
The Patent expired years ago and there are generic brands. Why are all of them going up this much? Something doesn’t feel right about this. Does this have to do with the glyphosphate lawsuit? Did some generic manufacturers quit making it? -
Low pressure on right side bank of injectors on Belarus 1500
MarkG replied to rodhergott's topic in General Chat
That is what I found on the internet for a Belarus cmd-62 injection pump. I’ve never saw anything like it. It looks to have two hydraulic pumping heads. One for each bank of the engine I guess. Try to bleed the bank that’s not pumping by running on the other bank. Funky design. Only good news I have is there under 500 dollars on eBay. No clue how you would time that thing. @Injpumped -
Starving for fuel or getting air would be my guess. Post a picture of the injection pump. If it’s a common type pump you will get many suggestions and good advice. -
I would like to know how you did it.
I changed the hydraulic pump on a 966 and the new pump had an extra port. When I asked about it I was told the same pump fits multiple applications. Some applications piggy back two pumps and this is what the other port is for. The extra port was blocked by the mounting plate in my application.
- 13 replies
- hitch pump
- hydraulics
(and 2 more)
Tagged with:
As far as generators not providing clean power that would be the inverter machines or the tiny pieces of crap that have poor speed control and poor voltage regulation. The inverter machines have evolved tremendously over the years and are quite good today. I would definitely buy the 540 pto driven and hook it up to the 1000 rpm pto. The engine speed at rated pto speed is about 2100 rpm. So if you used the 1000 rpm shaft you would only need about 1000 engine rpm. Assuming you live in a normal size house. 20kw should be plenty of power. 20kw is about 27 horse power. 27 horse power at 1000 engine rpm is nothing for a 1066. The formula is 1.34 horsepower for 1 kw. They use the 2 to 1 formula to oversized the engine. 2 to 1 is generally used for gasoline engines.
