sd186man
About sd186man
  • Birthday 08/21/1973
    Lemmon,SD
1,508 profile views
sd186man's Achievements
  1. Good luck finding one for about the same money, I paid 2500 for mine and had to completely rebuild it including the bolster, still worth every penny, the knees and spindles are same as 2wd magnum.get the wheels and lug bolts too, the standard wheels and tapered bolts will work, but the offset is wrong, and it cost about 350/side for magnum wheels and bolts, as I can’t find a source for bolts beside CNH for over $14/bolt.
  2. I don’t think a late 1086 axle has any similarity to a high capacity axle
  3. Can an 86 series be converted to the hydraulic trans brake?
  4. Thank you gentlemen, I will call Herrs, I do have a hose on it temporarily and it makes it growl loudly if you use the foot n inch pedal. I also tried a brake line with brass nuts a local auto parts store made for me but it didn’t last long until it was leaking, just out of curiosity does anyone know how much pressure those pipes run?
  5. Looking to buy on or two of these pipes, I don’t have the part number but was told they are NLA from CNH, thanks
  6. I’ll try to keep this short, forward works fine, reverse has a little pressure but not enough to move, found the servo cylinders and anchor pins leaking, rebuilt them, still no reverse. Went through the trouble shooting chart and found the check valve broken, replaced it, recovered the ball but 2 small pieces of the cage still missing. Reverse was still intermittent but then worked about 30 times test driving it, thought it was going to work. Took it home and it only worked 3 times and quit. Any ideas short of taking the whole hydro out and going through it? Thanks
