Jasher452x
    12
About Jasher452x
    Redfield, Iowa
  1. Jasher452x
    656 loader "jerky" on the way down
    Check to see if it has a double acting check valve. If it does take it apart and clean it. Those double acting check valves can act jumpy at times because the volume of the return side exceeds the supply side on the downward motion.
  2. Jasher452x
    Replaced Alternator on 1066
    the third pin is for a tach lead, On some engines and equipment this is where the Tach gets its signal
  3. Jasher452x
    606 pto won't turn off, advice please
    the 606 is a mechanical unit
  4. Jasher452x
    if it was parked with the PTO engaged, the clutches and steels may be seized together. not sure if you could hook it up on the PTO and see if it will come free... i am sure some one will have a way short of pulling the PTO out and rebuilding it.
  5. Jasher452x
    IH 504 Utility Serial # suffixes
    S=torque amplifier x=high speed low and reverse Y=12GPM pump FF=4.5GPM hitch pump
  6. Jasher452x
    Help my "new" 5240 won't move
    the two relays are not the same, the first one normally open, when activated send power from 30 to (2) 87 terminals, the other just sends it to one 87 when activated, 87A when not energized
