bjjk88
160 profile views
bjjk88's Achievements
2
  1. The two rollers inside the box are smooth almost feels like a felt material but they are tight against each other.
  2. It has a removable tray at the bottom of the box. Two rollers are attached to the crank handle and the smaller pulley.
  3. Just bought this at an auction and the auctioneer said it is a clover seed grader. Has anyone ever seen anything like this and if so how does it work and who made it? Thanks.
  4. I am thinking about buying a disc ripper but want some input if running one would help increase yields. I live in south central Illinois where most of my ground is light timber soil and some clay.
  5. To clarify the question I have to slow down the ground speed. After talking to a veteran combine mechanic this morning he told me that the priority valve in the valve stack is getting weak and needs shims added to it to correct the problem.
  6. Haven't changed filter in a couple of years. All other hydraulic functions run normal.
  7. I am running a 1020 head on a 1440 combine with electric over hydraulic controls. For the first couple of hours the head floats fine then it will start dragging dirt under the middle of the head. Also when I go to raise the head it won't raise until I slow the combine down some. Just wondering if these 2 problems are related and what could be done to fix it. Nothing worse than leaving piles of dirt and soybean residue in the field when you are finished combining.
  8. Yes, I have thought about putting weights on the tongue to counter balance it.
  9. I do not have an operators manual. Are the three holes located by the leveling crank on the front of the disc?
  10. I just mounted a tine harrow on my 496 disc and now it is causing a negative tongue weight on the front of the disc. I see used discs on dealers lots with harrows on them and they are balanced. Any ideas on how to fix this issue?
