larv71
    122
Everything posted by larv71
  1. 2.25" here along with snow flurries. It's been dry enough here that it soaked in well. Need some heat. Been cold and windy last couple of weeks. Ground has worked up as good as I've ever seen. Once over with soil finisher & rolling basket and it looks like a garden. Just need sun & heat.
  2. Replaced the bad brg and rechecked spring alignment. Went to the field and another brg started sqealing. Called the svc mgr/ head mechanic to come and check it out. Wanted to know where brgs came from, all new from your dealership. Took two with him back to the store and would call me within the hour. Called and said he split them open and were junk. Had grease zerks but not drilled to let grease into the bearings. Not even prelubed. Parts mgr was told to pull them off the shelf and call supplier. Got eight Case/IH brgs. Say they're BCA & American made. Rain now going to install tomorrow
  3. Appreciate feed back. I've had this disk probably 20 years, use it on 5-600 acres never had any major issues with bgs. He brought me a brg last night and I think this may be the issue. Almost no side movement. Think there probably china junk. Going to try to find some USA made and see if a difference. Will ck back . Thanks
  4. I have a IH 496 24' rockflex disk, my son rebladed the front gangs, all new earth metal blades, new bearings and half spools. Checked all the full spools and were fine. When the gangs were remounted you could spin them easily by hand. He tried working some ground today and ruined one bearing and half spool and can see another one starting to wear excessively. Only thing I think would be the rockflex springs out of adjustment. I'm not much help, had hip surgery two weeks ago. If anyone has any suggestions or have had the same problem would appreciate any feedback. Thanks in advance.
  5. Ethanol plant in South Bend was bidding $6.66 today. .15 over board. Long term not good. Wait till we go buy imputs for next year.
  6. It's a plow, started out with a Buckeye half track wheel machine to do my own tile projects. My boy got interested and started doing small jobs for neighbors, then upgraded to a Buckeye Super D. Got busier and purchased the plow for system tile projects and use a DynaPac 2400 trencher instead of Super D . Started this 9 years ago and now evolved into a full time business.
  7. Not a Dozer but does have tracks, Deutz power & hyd drive.
  8. Try Duane Miller, Bourbon In. Deals in planters, drills & hay equip. 574-849 3607. Hr might be able to help.
  9. Son in law's family have a Injection molding plastic business, running low on resin and getting hard to find. My son ordered 3 semi loads of drainage tile for a job, two price increases plus not everything available. Planted wheat for my own project this summer, told him to get it delivered before we can't get anything or price prohibitive. Luckily bought our fertilizer early. Prices thru the roof. I retail ag chemicals, should have had a lot of product delivered by now. Anything coming from across the pond is a problem. Either on its way or waiting in port to be unloaded. Going to be a
  10. larv71
    Cursing
    Most I ever heard from dad was dam or sh-t. Have tried to do the same. Worked in a machine shop years ago and it was tough not to bring it home.
  11. Im with tractormanmike, Culvers, cant beat their Butter Bugers!
  12. larv71
    The Dog Thread
    These are my two hounds Hank and Bertie enjoying the fruits of my labor. They're enjoying it much more than I am.
  13. I put a set of Yetter markers on my 7000 12 row. It came with a cycling valve for its own circuit. Also have similar valve on my no-till drill. Fairly simple set-up. Should be something generic on-line. Hope this helps.
  14. If it was closer I'd come. Fort Wayne Ind. farm show canceled about a week ago. Was moved from Jan. to March and still gone.
  15. Found this one from Reese Equip, Plymouth In.
  16. larv71
    IH Freezer
    Hope it went to a good home. $425.00
  17. larv71
    IH Freezer
    Ran across this on Polk's auction website. Looks to be in decent shape. Looks like the one my parents had 60+ years ago. Have no affiliation to sale or item.
  18. New congress woman I think.
  19. Ck with Mike Links @ Triple R Tractor
  20. Been on it for close to fifteen years for crohns disease. For me the benefits out weigh the risks. Most drugs either have side effects or the possibility of other ill effects. Take a shot every every two weeks. Was on three other drugs initially plus humira but have since dropped two and reduced the third but will probably always be on humira. If you suffer from crohns or colitis its not a pleasant experience.
  21. Reason for the season! Good job.
  22. As posted above the Val6 is probably best diesel fueled heater on the mkt. Mine will be going into its 5th season. So far only changed fuel filter. They are pricey but no need for kerosene which is ridiculous price. Mine has the hi/low switch which is nice. Pretty economical also. Had a hard time pulling the trigger because of $ but its been a good investment.
  23. X2 Have never missed a Presidential Election.
  24. larv71
    Vote!
    Left the house at 5:15 for a 10 minute drive to the polls, 118 ahead of me. Line was a minimum of 150 to 200 yards back when I got thru. Lines moved steady though. With all the early voting & absentee ballots, I've never seen anything like this.
