Bdse25
    722
Everything posted by Bdse25
  1. Bitty I also saw a bobcat out there today. And a porcupine. Both kinda rare around here
  2. So what were the early and what are the later MX series? Like a 210 was the series before a 215 right? So if the model ends in a 5 there the newer models. And which were known for electrical issues? Or are all the MX in the same boat there?
  3. So I’m in the market for a new larger machine. Thinking pull my 5200 Krause drill, maybe one day a big baler, tillage, and run a grain cart. Was looking at 5488’s, then started looking at magnums, then the MX series. My question is are the MX really that bad? It seems for a nice 7140 7240 8940 or 8930 you pay as much of more than a MX 210 or 215! I’d rather have something newer if the electric problems Arnt that bad. I know the CAPS fuel system is supposed to be a nightmare but I’ve heard conversions can be done as well. I’m not sure exactly on my budget yet but would rather spend a bit mo
  4. Yeah I’m in Allentown. I got your PM
  5. Hmmm ok so from what I’ve read here it seems like a Deere might be the way to go. I’ll have to keep my eyes open this fall
  6. Wow my biggest takeaway from this whole thing is how hard those drills must pull. I thought if need be I could get away with the 806 on one. Guess I was wrong ??
  7. So those Deere’s actually no till when they’re a bit worn? I like the idea of a full row of no till coulters for doing some residue management at the same time
  8. I don’t have any particular reason to like the Krause aside from them being common around here and looking plenty heavy. I always was onder the impression Deere’s we’re both expensive to buy and expensive to maintain with a ton of moving parts on the openers. The Krause just replace 2 discs and hit the road
  9. Palmerton PA. 30 minutes north of Allentown pa. View through the gap is of the Lehigh Valley about a month ago
  10. Hey guys, I’m looking to get into no tilling beans and cover crops more. The neighbor has a Krause no till drill and is super pleased with it, and just from looking at them they’re definitely really heavy. Anyone have one? How’s maintenance and repairs on them, any known weak spots? ive seen 5200NT and 5250NT drills locally. Any difference between the two or one better than the other? Would a 1486 pull a fifteen footer around on my hills? Pic for reference.... we’ve got hills
  11. After reading all this I’m going to refill them and check in a few hundred miles. We have maybe 5 loads of wheat to haul, then nothing until fall so plenty of time to rebuild if needed
  12. Both drain plugs have magnets in them and had the pieces stuck to them
  13. Both drain plugs have magnets in them and had the pieces stuck to them
  14. 3406 A set at 425 13 speed Eaton sounds like I’ll put fresh oil in it haul what I need to to wrap up wheat harvest and then pull them apart before fall. I guess it can’t be to expensive to get some bearings and throw them back together just to be safe
  15. It’s got a power divider. Rayco suspension. That piece on my finger came out the front rear with the power divider. The rest came out the back rear. With corn prices where they are im not trying to spend more than I have to
  16. Hey guys question for all you truck drivers and mechanics. I bought an 83 kenworth W900, and decided to get some fluids changed. Only hauls our grain 30 miles to the elevator. A few thousand miles a year. After dropping the drain plugs in the rears I found these pieces. I know from the previous owner that they never changed the oil in the last 5 years. You guys think this is an issue or just keep on running? No noises or anything to speak of
  17. Ah I would go buy two brand new belts, of the same brand and size and just tighten that puppy until they’re both tight. If they’re a matched set the tighter one will stretch enough to get the looser one tight. Lots of heavy duty applications using multiple v belts out there, just tighten her down till it’ll take the power
  18. Well it all depends what your composting. Keep in mind these are young hogs or birds!! Only a few months old realistically. Bones get calcified with age, and that is what makes them hard to compost. I speak from experience that feeder hogs will only have the jaw bone and one other( I think in the leg?) left after 6 months. An old cull dairy cow is an entirely different animal (pun intended) when it comes to bone decomposition
  19. I believe composting is proffered if possible, put out 4 foot of wood chips or so, lay in a barn of hogs( what is a barn 2500 I think? And push another few feet of some organic material over the top. Turn it in 3 months and there’s only teeth and a few bones left. Toss it in the spreader and problem solved
  20. Wow that’s a nice one! Great shape yet!
  21. Yeah that was made In an hour or two on photoshop by some moron. I bet if you google “ocean view” or something you find the background pic as well??
  22. Hahaha come to Pennsylvania sometimE probably over half the corn in the state is planted with 6 rows or smaller. And about 75 percent is planted with finger pickup units. Around here we make our money on a good corn basis and keeping costs low. Vac planters are “high tech” lol
  23. I’m guilty of this in an off road haul truck back in my surface mining days. Hit the lever into the detent to lower and took off. Lever must have popped back to the hold position When I swung in to get loaded the Guy in the hoe just shook his head. Sure felt lower than a snakes belly in a wagon rut at the safety meeting the next morning.......
  24. Bdse25
    Hi clear
    Saw a lot of stuff go way higher than I expected for full online. Very suprised
