1989 plowboy
Everything posted by 1989 plowboy
  1. There is a screen inside the lift pump take the single bolt out of the top and clean out the gunk inside lift pump is on passenger side of block
  2. I’m gonna start by saying I’ve never had the pleasure of owning a ih diesel we had 706 gas when I was a kid and I preferred it to other tractor s we had then because of how it drove straight on the road and I could put out 4x6 bales of hay and not have to steer with the brakes we bought a 806 gas for a couple thousand 11 years ago with the intention of doing this swap I was lucky and found two two wheel drive first gens for there engines I have 5500 or less total in the tractor and the swap it now lives on the tmr mixer it cranks good and sips fuel I do wish it had a cab to keep the rain off me though my swap is not as clean as most I’ve seen but it’s a low budget chore tractor that was originally a gas I’d do another in a heartbeat if I could find another cheap gas 806
  3. Thank you for the results I wanted to go see in person but you know how that works
  4. Eason did you make it to the sale today I was wondering what things brought ?
  5. Check the fire wall under the hood I’ve seen two fords of that year model bust firewall and it flex when pushing in the clutch
  6. It was 3200 a friend of mine also sent it to me but apparently it’s been sold I had to many things going on today he just text me may be a good thing
  7. How cheap is cheap to everyone here ?
  8. A 1486 is for sale locally with a busted driver side rear axle we’re a truck driver clipped a guide wire hauling it with duals on and it’s priced cheap enough will a 1086 trumpet housing and axle work I happen to know we’re a parts one of them is or is there a underlying problem that could cause this
  9. Can someone explain a 2806 then I was assuming it was more like a wheat land one neighbor has is a swept back front axle with pto and external steering cylinders but it also has 3point no ta
  10. Check and see if it has the sensor that alters timing when the engine is cold if it has it you can simply unplug it to test it
  11. Looks excellent you did a lot cleaner job than me I ran out of money when springtime came
  12. Try pb blaster / kerosene/ atf mix pull injectors and fill full let soak then go by and bump the starter every couple days time and patience are of the essence that way you will know what you have before you have to rebuild in the future
  13. Try upper 80s and 90 percent humidity
  14. Corn looks pretty good ours is all over the place that the 1066 ?
  15. Got ya never had to do that one I've heard it is a pain
  16. I was referring to back nut on injection pump What gasket were you replace ing ?
  17. Long 3/8 extension with universal joint
  18. Or was it last American rancher on planet green ?
  19. Wasn't it stucky ranch from last American cowboys that did it that way ?
  20. No I've got the old school juice with outlook monitor I believe on one and edge ez tow pros on the other two
  21. I read a little on it last night let me know how you end up liking it I'm always looking for more power lol
  22. No I've not heard of that one yet I used to be up to date on the Vp 24valve engines please in lighten me ?
  23. I've got it s mate great harrow think I put new 30 or 36 inch disc s on mine a few years back how many discs is yours ?
