wendyoakscubs
Calendar
Everything posted by wendyoakscubs
I have a 1200B pickup currently with a bad 304 v8 in it and access to a 404 v8 in a cab over IH grain truck. Wondering if the 404 v8 would bolt up to the existing 4 speed transmission in the pickup? Now, before I get the repetitive "whys" and all the other non useful info about a custom motor swap... This is a question to see if anyone out there has heard of it being done. I understand a 304 and a 404 are two different engine families, but I thought i would ask since I know the 304 is a wide bell housing bolt pattern engine (and assuming the 404 is also). I'm guessing the transmission would have to go with the 404 in the pickup. The 304 in it now has a cracked block and I'm not saving it. The 404 has low miles on an out of truck overhaul and runs well. One main reason I was pondering the swap. I've read the stories on the 404. Not surprised by any of them. They have goods and bads. Yes, many other engine swaps are probably better. I'm focused on hearing thoughts on this one. Yes, I can probably swap a 304, 345, or 392 easier than swapping the 404. Parting out the truck would be easier. Selling the 404 to buy the right motor, yes, I'm sure could be done. Yes, I could put whatever engine/tranny I'd like in it, depending on how much work I want to do. Just wondering if anyone has heard of it being done. Or has any experience around this subject. No bolts have been turned. Just a snowy night with plenty of time to think about crazy things. Any useful information would be much appreciated.
Yes, I had to cut the hole for the creeper. This one as I found it had no options. It got the options added over the years and then got painted in 2014. Just a rattle can job, nothing fancy. The Cub collection don't see much daylight anymore. Had this one out in 2020 for a local show. Other than that they sit.
Can't beat a good Original. One of my favorite models. Yours looks clean and straight. Here's my 4 digit.
You definitely want the shields on a gasser if you're going to do any picking in my opinion. My Super M with the 2MH gets plenty warm while picking. And I've only done two loads with it since I've mounted it.
I think I have a spare set for an M if you need some. Send me a PM for details If you'd like
1066 will 20.8 x38 tire fit 18.4 x 38 rim
wendyoakscubs replied to rodhergott's topic in Technical IH Talk
If you haven't modified your doors on the 1086 then hitting the doors isn't an issue. 1066 cab doors are hinged on the back of the door, 1086 hinged on front. -
Call Ertl and see what they tell you Matt.
Not necessarily farming related but tractor related. My son, who is 5, driving a Cub Cadet that he watched me fix and helped with a little bit. The big machines are still intimidating so we slowly start him out on something small and slow.
Bought two new matching cylinders online and put them on the loader last night. Everything works as it should. No more leaks in the valve and tilt function works great. Thanks to all who helped.
If the lever was stuck and you broke it free I'd assume the cable broke that actuates the TA. I'd double check that before I tore into it.
Update: I put the valve back together and the valve itself works great no leaks. Still have the creep in the tilt. I ran it to fully retracted and unhooked my hoses from the remote coupler near the right side fuel tank and the cylinders still will creep with the weight of the bucket and hoses unhooked. So, thank you for the suggestions to the cylinders leaking internally, because that's looking like the real culprit. The ones on the loader currently are not even a matching pair, two different bore sizes (a previous owner quick fix). So, I ordered a new pair of matching cylinders and will replace once they get here and I hope that solves the issue. I will report results once I get it fixed. Thanks again.
I have Samson brand on my 504. Came with the tractor and seem to hold up good so far for a Chinese tire. Also have a set of Samsons on my 560. They are 16.9-38. I installed 5 years ago and no issues so far. Haven't used it hard but enough to warrant saying they are decent for the money. Rather have Firestone but here cost is an issue sometimes.
Thank you for explaining. That makes sense. Sounds like it would be unrelated to my issue. Probably worn spool and valve body. To rule it out I will try new o rings and clean up springs and balls for detent and try it. Maybe spool wasn't centeri g 100 percent of the time causing leak by. Next I could test tilt cylinders.
Very well could be. After tearing that apart last night everything had that rusty oily gunk inside (not in the valve, but inside the pipe where the detent springs are). It's obvious that the valve has wear, but possibly those items inside could have been holding the valve open slightly sometimes allowing it to bleed out. I'd be more convinced if this did it every day, but somedays it functions just fine. Someone has modified this loader like a 2000 loader I believe, with two lift cylinders along the front beams of the loader rather than one in the center. Cylinders are newer, which don't mean anything but aren't leaking yet and I thought I would tackle the leak first in the valve. Another question, what does the unlatching piston do in the valve? Has the little o ring on a small shaft behind the detent balls? Does it relieve pressure inside the valve so one can connect hoses downstream? I thought maybe this could be an issue with the creep but I won't be surprised if I'm wrong.
Tonight I took apart my outside remote valve as it had been leaking and also controls the tilt function on my 2001 loader. 90 percent of the time I use the tilt function on the loader, I return the valve to neutral and the bucket slowly creeps, or tilts, downward. It won't stay in the desired position. The other 10 percent it will hold where its been placed and hold a load just fine. I figured my creep issue would be in the valve. I see no torn o rings but a pretty stiff unlatching piston and some very slight scratches on the valve itself. What's causing the bucket to creep? Is putting new o rings in going to solve my issue? Any insight would be appreciated. Thank you.
IH 2001 loader lift cylinder seals
wendyoakscubs replied to wendyoakscubs's topic in Technical IH Talk
Yes, I haven't opened either one and I'm in the process of returning. Or if someone needs them I'm happy to deal. I assumed that there wasn't anything interchangeable, just thought I'd double check and make sure it wasn't a one kit covers all kind of deal. Like I said wiper seal in the kit was too small anyhow. Appreciate your time and thank you for your time posting the pictures. -
Update: I called my dealer with part numbers in hand, and as was said before in previous posts this kit was not available together but they had the part numbers there and they had most of the parts in stock for one cylinder. I ended up ordering since I needed seals for both sides. Thank you @7and8and1456 for posting the pictures. That's exactly what I needed. -
I'm going to take a guess that the kits I ordered will be for the 2 way cylinder, seeings how there are more pieces listed in the parts diagram. -
Thank you very much for posting these diagrams! My 2001 is pressure up, gravity down, mounted on a 504 utility (I have a conglomerated mess for bucket cylinders, but not relevant at this time) Looks exactly like the second parts breakdown you posted. Would the kits I have currently have some parts that would fit this cylinder, or would this be a kit for the 2 way cylinder? I could see if my dealer recognizes these part numbers listed. -
Thanks for the reply. I forgot to add that I did buy that kit, not from Baum, but from Reliable Aftermarket parts on ebay. Same part number. It's not even close to what I have. By looking at the kit, now seeing what I have inside my cylinder, i assume is for the original tilt/bucket cylinders. Wiper seal in the kit is smaller inner diameter than what mine is. I can see the components in the kit and they are smaller and there are also about twice the seals and o rings in it than what I pulled out of my cylinder. I guess that's why I'm here. I read all of that thread, even before I ordered these kits to confirm. Still not right. I could be wrong, I'm just assuming I either have odd cylinders or I didn't get the right stuff. -
Thank you. I may end up having to do that. I have a number off the wiper seal and it looks readily available but the o rings will be the next battle. -
BIL just recently put a 4BT in his M. Made one heck of a tractor out of it. Came out of a generator I believe.
Hello again all, I was looking to find the internal seals and o rings for the lift cylinders on my IH 2001 loader. Is there still a kit available to repair these cylinders or do I need to order each o ring and seal individually? I have it apart and I see the wiper seal, two o rings and two white Teflon type seals that go on both sides of the main o ring. I didn't know if there was anyone out there that had the paper parts manual to look up part numbers for this loader. Im guessing my dealer does not have these anymore.. Both lift cylinders leak and would just like to see if new seals would slow it up for a while. Thank you.
Thread insert for head bolts? ( any experience?)
wendyoakscubs replied to dale560's topic in General Chat
I did a helicoil for my D236 when I had the head off. Been working fine. Torqued to specs and then retorqued after running. That was 1/2-13 bolts. -
That is a nice setup. Before this disk I had a 470 18 ft. Really liked it as well, but found this locally and this was in better shape plus has the hydraulic wings. Manual wasn't terrible but a lot of time bolting and unbolting to fold up to go down the road. Dad had the same size in a 490 behind his 1206 row crop and it was all it wanted here.
